by Jeff and John
Tooley
It all begins at framing: The earlier in the process builders start
thinking about air-sealing, the more energy-efficient, durable, and
comfortable a home will be.
As building scientists working to improve the durability, comfort,
and energy performance of homes, we spent years back in the 1980s
trying to make houses more airtight. The initial efforts focused on
things like sealing and caulking windows and weather-stripping
doors. But that was before we realized it would be much more
effective to focus first on the framing.
Our initial testing of house air leakage began by using blower-door
equipment to map the air-pressure boundaries of houses. A blower
door measures air leakage through the building envelope (a sandwich
assembly of framing, air barrier, vapor barrier, and insulation
materials that makes up the home's walls, top-level ceilings, and
floors), using a powerful fan mounted in an adjustable frame that
fits tightly into an exterior door opening (Figure 1). The fan
blows air into or out of the building. Sensors in the blower door
measure the airflow through the fan and the air-pressure difference
between inside and outside. This information is fed to a small
computer, which uses it to estimate the building's air leakage
rate.
Figure 1. A blower door consists of a powerful
fan that is temporarily sealed into an exterior doorway of a house.
The fan blows air out of the house to create a slight pressure
difference between inside and outside. House airtightness is
determined by the amount of airflow that it takes to maintain a 50
Pascal depressurization of the house. The tighter the house, the
less air that's needed to exhaust in order to maintain the
pressure.
This procedure helped us gain a better understanding of where
houses leak air. Over the years, we've improved our evaluation. Now
when we pressurize a house to 50 Pascals with a blower door, we
insert probes through small drilled holes into walls or floors that
we can't see into, and we can compare the pressures within those
assemblies to the pressures in the living space. If the interior is
at 50 Pascals, the outdoors is at zero (or neutral), and the space
inside a framed wall or ceiling is also at zero, then we know that
the space within that wall or ceiling assembly is essentially
outside the house. The instruments showed us that a lot of framed
assemblies — like chimney or vent chases, drop ceilings,
attic knee-walls, interior partition walls, or floor systems
— tend to have big voids that communicate directly to the
outdoor air. Floors or walls that we thought of as being inside the
house were really more connected to the outside, and they were
letting in the heat, cold, or humidity of the unconditioned outside
air.
Caulking around the windows may seem important, but a large hole
between the house and the attic is probably ten or a hundred times
more critical. The example below ("A Room with a View, A Porch with
a Problem") — a beachfront house that suffered significant
moisture damage because of air infiltration through a floor system
connected to a porch roof — is only one of the many cases
we've documented in which big air leaks through framed assemblies
have caused a house to malfunction.
HIGH-PERFORMANCE FRAMING
Now that our investigations of existing homes have given us a good
idea of where the major air leaks typically occur, the diagnostic
equipment is less important. You don't necessarily have to test
each new house — just knowing where houses typically leak can
help builders work more effectively.
The big concept. To build a
high-performance house, the designer (or builder, if you're doing
the design work yourself) should call out on the plans the location
of the air-pressure boundary for the house and the details that are
required to maintain that boundary at various framing
intersections.
First, the builder needs to make sure that the appropriate
materials are on site during framing, and the framer has to address
any potential gaps or disconnects in the conditioned envelope at
the framing stage — such as installing solid blocking or
solid sheet materials wherever they're needed to complete the
air-barrier assembly.
Second, in our experience, the insulation and air barrier should be
in contact with each other at all times. This reduces the
possibility of having air channels between the insulation and air
barrier that may lead to convective losses.
Any holes for wiring, plumbing, vents, and so forth that get
punched through that sandwich of air barrier, vapor barrier, and
insulation materials should be carefully patched by whatever trade
made the hole. We've found that if the three systems — vapor
barrier, thermal boundary, and air barrier — aren't installed
in continuous contact with one another, and if their integrity is
not preserved right through the end of the job, they don't function
nearly as well. Some areas, like plumbing chases, dropped soffits,
chimney framing, and unlocked floor structures, can create places
where the air barrier and the insulation are misaligned. When the
thermal and air barriers are misaligned, the insulation is no
longer insulation; it is a high-efficiency air filter. In addition,
voids and gaps in the insulation can cause convective loss between
the insulation, drywall, or sheathing that short-circuit the
insulation. All of these thermal bypasses compromise the energy
efficiency, durability, and comfort of the whole building.
Coastal conditions. These principles are
even more important for homes in a coastal climate. On the coast,
you've got the driving force of wind to contend with. Other forces
that move air through houses, like the "stack effect" (the tendency
of heated air to rise through the house on a cold day) or the room
pressures created by air supply and return ducts, tend to operate
intermittently when the equipment is operating or when the weather
is very warm or very cold. But onshore and offshore winds can blow
for weeks and months at a time — they're a constant force in
the coastal environment.
Besides the potential for condensation and moisture damage, the
latent heating or cooling load (see Soundings, in this
issue) caused by moisture-laden wind intrusion can waste
significant amounts of energy. We've also seen fireplaces,
furnaces, and water heaters back-draft just from the suction
created inside leaky houses by wind passing over the house. All of
those performance issues can be minimized when the house is framed
to be airtight and penetrations are carefully sealed.
PLUGGING THE BIG HOLES
If houses were just simple boxes, it would be easy to define and
detail the air barrier at the framing stage. Basic ranch houses
don't offer much trouble in this regard. But most houses these days
have at least a few complex shapes that make a hole in one space
and a bump into the adjoining space, and many houses are loaded up
with that kind of element.
Here are a few of the top troublemakers:
• Chases for vents, fireplaces, or pipes
• Drop ceilings, coffered ceilings, and "tray" ceilings
(Figure 3)
• Cantilevers where floor systems overhang walls or bay
windows that project out
• Stairways, especially stairways that connect to attics
• Attics that connect to floor systems, such as a knee-wall
attic in a story-and-a-half house or a porch attic that adjoins a
floor system (see "A Room with a View; A Porch with a Problem,"
below)
A quick look at a couple solutions to such problems will help you
understand how to stop the air through these critical junctures at
the framing stage:
Attic-to-cathedral transitions. Consider, for
example, the changes in ceiling elevation in the house shown in
Figure 2. The framer has used rigid sheet to face the backs of the
vertical stud walls between the conditioned high-ceilinged space
and the unconditioned attic adjacent to it. In one case he has used
OSB; in the other he has applied Energy Brace, a heavy
cardboard-like material with a foil or plastic facing from Ludlow
Coated Products (www.ludlowcp.com). Energy Brace is a less expensive
air barrier than OSB, and it is only about 1/8- to 1/4-inch thick,
so it can be conveniently added to framed assemblies without
significantly affecting their dimensions.
Figure 2. At left, the framer used OSB over
vertical stud between the space below a cathedral ceiling (created
with scissor trusses) and an unconditioned attic. In the same
house, framers applied Energy Brace as a backing between living
areas and the attic (bottom). In each case, the solid-sheet
material provides a stable, airtight boundary around this home's
conditioned space that can be insulated to preserve the thermal
barrier and air barrier at once.
These wall stud cavities can now be insulated and drywalled, and
they'll form a segment of the continuous, stable, airtight, and
insulated boundary around this home's conditioned space. Without
the rigid materials applied during the framing phase, the insulator
and drywaller might end up confused about how to detail this
juncture — and it might end up without its insulation or
without its air barrier, or without either one, as we have often
seen.
Raised or lowered ceiling profiles. In Figure 3, we
have two complex architectural ceiling details, framed in beneath a
truss roof. On the right, a two-level soffit drops below the main
ceiling plane, and on the left, an octagonal coffer, or tray, rises
above the main ceiling plane. For the soffit, the framer has
applied OSB to the bottom truss chord before framing in the detail
beneath. For the octagon raised ceiling, the framer has applied OSB
to the top of the extra framed element. In each case, the OSB will
serve to isolate the occupied space beneath from the unconditioned
attic above. The insulator now has simple flat planes to apply his
attic insulation to, instead of having to puzzle over how to place
it.
Two architectural ceilings framed beneath a
truss roof have been backed with OSB. In each case, the OSB
isolates the occupied space from the unconditioned attic, providing
the insulation subcontractor with simple flat planes on which to
apply his attic insulation, instead of forcing him to puzzle out
how to fit insulation into complex cavities.
Even the most complex framing elements can usually be dealt with in
a similar manner. But the key is teamwork: the designer, the
builder, and the framer have to be on the same page and stay in
communication in order to accomplish these details at the most
practical point in the construction sequence.
We feel not enough coastal builders have adopted the framing
techniques outlined here. But the techniques are simple enough. The
sooner builders start thinking about air-sealing at the framing
stage, the sooner homes will start to be more energy-efficient,
more durable, and more comfortable. ~
John Tooley Sr. is a building scientist with Advanced Energy
Corp. in Raleigh, N.C.; Jeff Tooley owns and runs the Healthy
Building Company, based in Siler City, N.C.
