It's been a snowy winter in the mid-Atlantic and Northeast
snowy and cold, with little if any thawing or melting between
successive heavy storms. As a result, snow loads on rooftops
are piling up in coastal New England. The latest storms brought
a rash of roof collapses to Massachusetts, Connecticut, Rhode
Island, and New York.
The Boston Globe had this report on February 3, complete
with video of the failure of a flat-roofed commercial building
in Easton, Mass.
Building collapses continue; more storms on horizon ).
Boston TV station WCVB has this additional report
Roofs Collapse After Storms Pound Bay State, by M. R. F.
Buckley. The
video of
the Easton collapse is also posted on YouTube.
Rain and sleet on Saturday, February 5, increased the risk,
the Globe reported
Today's rainfall could worsen the threat of roof collapses,
by Janet Walsh). At a Chelmsford, Mass., mobile home park,
three trailers were judged uninhabitable by local officials
after a resident called about a sagging roof.
Rhode Island structural engineer David
Grandpr©, P.E., was busy over the weekend
chasing down reports of trouble. Grandpr©
handles structural investigations for C.A. Pretzer Associates,
Inc., based in Cranston, Rhode Island.
Grandpr© talked with Coastal Connection on
Monday. The most vulnerable buildings, he said, are commercial
flat-roofed structures built before the codes began to require
engineers to take account of drifting snow. In Rhode Island, he
says, that change occurred around 1978.
When you have a change in roof elevation, snow can either
blow off from the high roof and land on the low roof, or it can
pile up against the wall of the higher portion on the lower
roof, Grandpr© explains. Both scenarios are
considered in current building code requirements for designing
for snow. You just add all that weight at that one concentrated
area.
In the current snow event, says Grandpr©,
I would say there are a lot of problems associated with snow
drifting. I looked at one case where they built a new addition
with a lower roof than the main building, and the people
designing the lower part didn't seem to know that there was an
existing higher roof. And then the opposite also happens, where
there's an existing low roof, and somebody builds an addition
higher, and they don't take into consideration reinforcing that
existing lower roof.
Commercial building collapses are indicative of flaws, says
Grandpré: The large majority of buildings that are
falling down and touching the ground have some sort of
construction or design defect. Even this February's monster
Groundhog Day storm should not have collapsed a properly built
structure, he says: The snow loads that I've been seeing are
not really that much above the typical design criteria of 30 to
35 pounds per square foot. Those roofs should be able to hold
that much weight. Engineered design methods involve the
application of significant factors of safety, he points out so
if we're seeing roofs come down with close to the design snow
loads, then there's got to be some kind of construction or
design defect.
Grandpré has also looked at some houses with snow
problems. But in these cases, he says, the trouble has been far
short of any structural collapse, and may not signify any
construction or design deficiency. Light wood-frame residential
buildings, such as a typical ranch house or colonial, can be
well built and code-conforming, says Grandpré, and
still have trouble. Codes specify an allowable deflection for
floor or roof framing under the design loads, he points out;
and when there's enough snow on the roof, that amount of
deflection could cause finish or performance problems without
risking an actual structural failure.\
We use the equation L/180 for deflection, Grandpré
explains. So if we have a 180-inch span, that member is allowed
to deflect one inch under load. If you have a 360 inch span 30
feet you could have two inches of deflection. But when you have
a two-inch deflection, ceiling panels can go out of whack,
sprinkler heads can drop, sliding doors can bottom out. And all
that can be well within the safe limits of the performance of
the structure. But they cause distress, and it's a good idea to
have them checked out, just in case a structure really is
failing.
The house Grandpré inspected this weekend had a
wood paneled ceiling and faux wood beams. When the trusses
deflected, those faux wood beams got pushed down and started
separating. Gaps were opening up by the end of these beams. But
it looked like the roof was caving in. So they got a contractor
to shovel off the roof, and the trusses rebounded a little bit;
but the beams got stuck in the new position. So the ceiling's
going to have to be replaced. And it's very frightening for the
homeowner, but it's really just an esthetic problem, not a
structural safety problem.
Besides that, Grandpré said, the home's sliding
patio door got stuck because the wood header over the door
deflected under the weight of the truss ends.
Grandpré assured the homeowners that the house was
safe for their Super Bowl party this Sunday. But he says, This
speaks to the nature of the building code. It says right at the
beginning of the code that the code is a minimum criterion.
It's the owner's prerogative to do more than that minimum. And
on high-end houses, we often go above the code. You can spend
more, and get more, if you intelligently put your money in the
right place.
