by Mike
Guertin
In the days after a nor'easter or tropical storm hits Rhode
Island's south-facing coast, I invariably receive a flurry of calls
to investigate "leaking roofs." Most of those "leaks" are the
result of wind-driven rain entering the vents high on the roof
— typically through the ridge vent and gable-end vents,
though occasionally through the soffit vents as well.
In my efforts to reduce these callbacks, I've tried a variety of
products, like low-profile or baffled ridge vents and aggressive
louvered gable vents, but none of these consistently keep out
moisture. A product that may resist water penetration on one house
inevitably leaks on another. This may be due to differences in roof
pitch or in the angle of the roof to the storm's force. I haven't
always been able to determine the exact cause, and I've yet to find
a foolproof, one-size-fits-all solution. However, in the last eight
years of working on this problem, I've come up with some workable
strategies, while also dancing across the lines between what
building codes and shingle manufacturers want and what actually
works.
Navigating Codes and Warranties
Since most of the storm-driven water intrusion I've seen has come
through the holes we purposely put in roofs (gable, ridge, and roof
vents), I avoid them whenever possible. In other words, I often
prefer not to vent coastal roofs. But that's not always so simple
in practice. The International Residential Code (IRC) has two
provisions that "require" roof ventilation. The first, in the "Roof
Ventilation" section R806, explicitly requires ventilation for
attics and cathedral ceilings. The second, R905.1 in "Requirements
for Roof Coverings," instructs builders to follow the
manufacturer's installation instructions (which, of course, usually
require ventilation). To calculate the amount of roof ventilation
required, see Roof Ventilation by the
Numbers.
Roof ventilation is required by building codes and manufacturers
for a few reasons. For starters, ventilation cools the underside of
the roof sheathing, which prolongs shingle life and reduces heat
gain in the living space. Ventilation also reduces the chance of
ice damming and flushes out moisture vapor entering the attic or
roof assembly through air leaks from inside the house.
In order to install an unvented roof, I need a cooperative building
official who's in tune with building science research on unvented
"compact" or "hot" roof designs. Unvented roof designs aren't new,
and they've been used successfully for many years. The key to their
problem-free installation in a heating climate is to create an
airflow barrier/retarder that prevents leakage of warm, moist air
into the roof assembly during the heating season. Stop the
vapor-laden air from reaching a condensing surface (the underside
of roof sheathing, for instance), and you won't have condensation.
I use a two-layer system to accomplish this: After insulating, I
cover the ceiling joists and truss bottom chords or underside of
the roof rafter drywall with an airtight vapor barrier. Then I
carefully seal any penetrations through the drywall.
Most officials to whom I've presented unvented roof designs have
been amenable to the idea and have approved my plans. When
officials have concerns and don't approve my alternative designs, I
go to Plan B: I meet the code by using soffit vents at a 1:150 vent
space-to-ceiling area ratio. And I still install an airtight
ceiling, knowing that the soffit vents alone will do little to
evacuate moisture vapor.
Even with an obliging code official, there's still the sticky point
of shingle manufacture warranties. If you don't follow the
instructions, you void the warranty, despite a large body of
evidence that climate, roof exposure, and shingle color have a much
greater effect on roof temperature than ventilation does. So I
resign myself to the fact (and explain to my clients) that
installing an unvented roof may void the roofing material
warranty.
Soffit Leaks
In my experience, soffit vents let water inside only when the plane
of the soffit is at a level equal to, or above, the wall top plate
and ceiling inside, and when the vents are strip or rectangular
style. This is most common with raised-heel trusses, but may also
occur when a bottom chord overhangs a truss. I've never seen water
enter soffit vents on cut roofs or top-chord overhang trusses in
which the soffit is below the top plate and the ceiling plane. I
suspect that some wind-driven rain gets into the soffit in the two
latter cases, but there's not enough air pressure to drive it up
and over the wall. Instead, the water drains back out through the
vents or at the soffit joints.
With this in mind, I detail vents differently when the soffits
match the wall-plate line. I start by leaving a 1 1/2- to 2-inch
space between the inside edge of the soffit panel and the wall.
After the siding is installed, I mount Cor-A-Vent S-400 soffit vent
strips (Cor-A-Vent, 800-837-8368, www.cor-a-vent.com)
over the top edge of the siding and cover it with a 1x4 or 1x6
frieze board, leaving an attractive shadow line (Figure 1). There
are a number of vent details you can devise using S-400, depending
on the exterior trim details of the house. Alternatively, you can
use a behind-the-gutter detail using DCI Products' FaciaVent (DCI
Products, 800-622-4455, www.dciproducts.com). In both cases, the
products and details create vent paths of several inches at right
angles to the soffit that resist water intrusion.
Figure 1. To prevent wind-driven rain from
entering the soffit, the author details soffit vents as shown
here.
Custom Gable Vent
Remodeling projects often present one problem I can't overcome: an
existing ceiling that isn't airtight. I try my best to seal
penetrations, such as lighting fixture boxes, wall-plate joints,
and other obvious air-leakage points. On projects that include
replacing old roofing, I know I'll need to include adequate
ventilation to flush out moisture, especially when we're installing
ceiling insulation. Soffit vents are a given, but I want to include
vents higher on the roof to maximize the ventilation's
effectiveness. For this, I borrow a gable-vent design I found on an
old shingle-style home (Figure 2).
Figure 2. On remodels where the ceiling plane
is too porous to ensure a safe "hot roof," the author builds this
eyebrow gable vent.
To create this gable vent, I first side the wall to a course about
4 feet down from the gable peak. Then I take a 1x10 or 1x12, and
cut it into a bow about 3 feet wide with an oblong hole in the
center, leaving 1 inch to 1 1/2 inches of material around the
perimeter, as shown in Figure 3. After covering one side of this
bow with insect screen, I mount it to the wall about 1 inch up from
the bottom of the next shingle course. About 8 inches above the
bow, I cut a 12-inch hole through the sidewall sheathing.
Next, I cut one or two tapered 2x "rafters" with a base that
matches the width of the bow. The rafter supports the middle of a
1/4- to 3/8-inch plywood cover that forms the shape and structure
of an eyebrow. This custom gable vent provides a right-angle vent
pathway for air that proves reasonably weather resistant. Still,
such a high gable vent needs to be coupled with soffit vents to
provide effective attic ventilation.
Figure 3. To create this gable vent, Guertin
begins by cutting a bow like this from a 3-foot-long 1x10 or 1x12.
About 8 inches above the bow, the author cuts a 12-inch hole
through the sidewall sheathing, then frames an eyebrow with
triangular 2x rafter blocks. This structure will be wrapped with
3/8-inch plywood and shingled over, as seen in the photo
above.
Hot-Climate Roofs
My experience is primarily in coastal heating climates, but what
about coastal roofs in cooling climates? Typically, builders don't
worry as much about moisture vapor entering the roof assembly from
within the house. Instead, they have to worry about thermal
moisture drive.
Moisture condenses on the roofing as nighttime surface temperatures
drop. Capillary action wicks water between the shingle laps, and
when the sun returns the next morning, and roof surfaces heat up,
driving the water between the shingles away from the surface,
through the underlayment, and into the roof sheathing. To prevent
moisture from being driven into the roof, Joe Lstiburek of Building
Science Corporation, a leading building-science consulting firm,
recommends using a less permeable roofing underlayment,
particularly over unvented roof assemblies where thermal-driven
moisture can get trapped and is slow to dry. (For more information,
see the Building Science Corp. article "Unvented Roofs, Hot-Humid
Climates, and Asphalt Roofing Shingles," www.buildingscience.com
resources/roofs/unvented_roof.pdf.) Several new roofing
underlayments meet the permeability criteria for this application,
including Tri-Flex 30 (www.flexia.ca/products/building/construction.asp),
Typar RoofWrap 30 (www.typarhousewrap.com/roofwrap.html), and
Titanium-UDL (www.interwrap.com/titanium/Ti_FCPhysical.html).
Promising Future
One product I have not used, but look forward to trying, is X-Treme
X-5 from Cor-A-Vent. The X-5 has a hinging baffle that closes and
seals the vent opening when winds exceed 10 mph, reportedly
preventing wind-driven rain and snow from entering. The
manufacturer claims that the harder the wind blows, the better the
vent seals. And while a storm's force closes the windward side of
the vent, the leeward side remains open. — M.G.
Mike Guertin is a builder and remodeler from East Greenwich,
R.I., and the author of the book Roofing with Asphalt Shingles
(Taunton Press, 2002).
