Have Asphalt Shingles Improved? - continued
Sidebar: Some Satisfaction from Shingle Suits
Tougher standard enforcement has evidently improved today's
shingles, but that doesn't solve the problem of customers who
have older, defective shingles on the roof. But court action
has begun to provide a remedy.
Every manufacturer reportedly experienced some cracking and
splitting of shingles installed in the late 1980s and early
1990s. Complaints were widespread, but individual homeowners
had little luck in court. Now, however, several companies have
been held accountable in class action lawsuits. GAF Corporation
settled with lawyers for homeowners in 1999, and Bird
Corporation reached a final settlement in February of this
year. A suit against Elk in Connecticut's Federal District
Court is being hotly contested.
Agreements in the two settled cases are similar. Lawyers for
the homeowners have insisted on four main elements:
• Warranty defenses
dropped: GAF agreed to abandon its usual warranty
defense that improper installation had caused the failures.
Regardless of how the shingles were installed, the company
agreed to provide compensation for failed shingles. Bird still
holds to some installation defenses, but they are
restricted.
• Money for tear-off and
labor: Typically, warranties have covered the product,
and that's it. Most warranties have never paid to remove
existing shingles when replacing a bad roof, or even for the
labor to install the new shingles. Contractors or homeowners
have been left holding the bag for what is usually the bulk of
a reroof's cost. In the two settled cases, however,
manufacturers agreed to provide money toward tear-off and
reroof expenses.
• Transferability:
Most warranties have never been transferable — they
cover only the original buyer. But since the average homebuyer
only keeps a home for seven years, shingle failures have often
occurred (or been noticed) only after a new owner has moved in.
Under the terms of the settlements, companies must compensate
second and third owners if shingles fail prematurely.
• Independent
review: The manufacturers remain responsible for
evaluating claims and deciding whether or not the settlement
covers any given complaint. However, a claimant who disagrees
with the company's decision has the right to an automatic
appeal to a designated independent third party. The company
pays for the review, whatever the outcome.
The bad news for roofers and builders is that the
class-action settlements cover homeowners, not contractors. If
you've replaced a bad roof at your own expense, don't look to
be compensated out of these lawsuits. On the other hand, if you
have trouble right now with a GAF or Bird roof you put on in
the late 1980s or early 1990s, your customer is probably
entitled to collect from the manufacturer to pay for a
replacement.
Information on the lawsuits is available on the World Wide
Web. For Bird shingles, go to
www.birdshingleclaims.com or call
800/247-3047; for GAF shingles, go to
www.gaf.com/settlement or call the GAFMC
Warranty Claims Department at 800/458-1860. Attorneys for the
plaintiffs in both cases, as well as the ongoing suit against
Elk, are Gilman & Pastor, Stonehill Corporate Center,
999 Broadway, Suite 500, Saugus, MA 01906; 781/231-7850.
—T.C.
