- Q.No-hub rubber couplings
with band clamps on the ends are handy for making all
sorts of plumbing connections, but are there
limitations on where they can be used?
A.Mike Casey, a licensed
plumbing contractor and co-author of Code Check
Plumbing, responds: Often referred to as
Fernco fittings (after the name of a major
manufacturer), flexible neoprene and elastomeric
PVC couplings are available in dozens of sizes and
configurations. They’re designed for
nonpressure (drain, waste, and vent) applications,
and are manufactured in shielded (completely
wrapped in stainless steel) and unshielded
(stainless band clamps at each end only) versions.
They’re accepted by a number of codes
— including the Uniform Plumbing Code and
the International Plumbing Code — for both
above- and below-grade use.
I’ve installed many of these couplings
above and below grade and have never encountered a
problem. Be aware, however, that the listings for
some of the couplings indicate that use above grade
is subject to approval by the local building
official. Always use the correct coupling for the
pipes you’re connecting, and check with
your inspector when the coupling is used above
grade.
