A.John Evans, codes and
standards manager with Icynene, responds: Most
building codes require that foam plastic insulation
— including both rigid and open-cell
low-density foam products — be separated
from occupied living space (including basements) by
an approved 15-minute thermal barrier.
While 1/2-inch gypsum board is recognized for
this purpose by most codes, other less-common
materials that can be used are sprayed-on
cementitious coatings (A/D Fire Protection Systems,
www.adfire.com ) and
mineral-fiber coatings (American Sprayed Fibers,
www.asfiusa.com). Before using
a system not specifically mentioned by code, of
course, it's always a good idea to consult first
with your local building inspector.
In concealed spaces — like crawlspaces
or unvented, conditioned attics — where
there's no occupancy, an ignition barrier is
usually required. Most building codes specifically
approve 3/8-inch drywall for this purpose, but
other options include spray-on intumescent paints
— such as FF 88 (International Fire
Resistant Systems,
www.firefree.com ) — 1
1/2-inch mineral fiber, 1/4-inch wood structural
panels, and .016-inch-thick corrosion-resistant
metal.
In some unvented, conditioned attic
applications, Icynene has been approved for use
without an ignition barrier; for details, see
Icynene's ICC-ES NER-420 report. Again, consult
with your local code officials before choosing this
approach or deciding on a specific ignition-barrier
product or material.
