There's an almost unbelievable amount of misinformation on the
market about building wooden fencing. A visit to any bookstore
or lumberyard that caters to the weekend handyman will turn up
an abundance of how-to books containing the same plagiarized
misinformation, all of them obviously put together by writers
and editors with no real-world experience in the trades.
That's bad news for a lot of amateur builders, but it does
ensure a steady supply of work for me. My business, The Fence
Doctor, specializes in building and repairing wooden fences.
I've found this to be a very profitable market niche because
few fencing contractors have any interest in doing repairs. The
tools required are minimal: My basic kit consists of a pair of
5-foot iron wrecking bars, two fiberglass-handled shovels, a
reciprocating saw, a nail gun, a posthole digger, and a 4-foot
level. Many of my customers call me after seeing a classified
ad I run in the "Fencing" section of a local weekly paper. I
also get some business through referrals from local insurance
adjusters.
In my area of suburban Minneapolis, I charge $100 per
replacement post, assuming that the original fencing itself can
be reused. There's virtually no competition, and few customers
balk at the price. With the right technique, the typical
three-post repair job often takes no more than an hour or two,
and sometimes less: A helper and I once completed a nine-post
job in just three hours. There aren't many areas of
construction for the small contractor that pay so well.
Fence Construction
The vast majority of fences that I work on are 6-foot privacy
fences consisting of 4x4 posts about 8 feet on-center with
infill panels of vertical boards. In most cases, the boards are
nailed to horizontal stringers that are toe-nailed to the
posts.
The weak link with this system is the posts, which quickly rot
out just below the soil line. Although this is often blamed on
moisture, the real cause is a bacterial enzyme called
cellulase, which is active in the first 6 inches or so of soil.
(In nature, it's what breaks down seed pods so that seeds can
sprout.) I have replaced hundreds of fence posts, and every one
shows the same characteristic damage (see Figure 1). Most of
the rotted posts I encounter are made from untreated cedar or
redwood, but this problem affects even pressure-treated posts.
I estimate that a third or so of the posts I've replaced over
the years were pressure-treated.
Figure 1.Fence posts that may be relatively solid
well below grade typically rot through in the top 6 inches of
soil, where enzyme-producing aerobic soil bacteria are most
active.
Setting the base of the post in concrete doesn't help at all,
because the worst damage is always near the surface. The only
thing I've found to work is setting pressure-treated
replacement posts in concrete all the way to the soil line,
which eliminates direct contact between post and soil. It's
also essential to fill the hole with concrete all the way to
the bottom: Partially backfilling with dirt and pouring a
concrete collar at the top saves some concrete but gives the
frost a flat surface to push against and will quickly cause the
post to heave.
Removing and Setting Posts
Whenever possible, we try to reuse the original fencing panels
and replace only the posts. Unlike the posts, the fence panels
aren't in contact with the soil, so they're much less prone to
decay, making reuse a practical option in most cases. But
because the wood is typically dry and brittle, it's likely to
split if you attempt to pull out the toe-nails that hold the
horizontal stringers to the posts. To avoid that frustration,
we simply cut through the nails with a bimetal demolition blade
in a reciprocating saw (Figure 2).
Figure 2.The crew first cuts through the toe-nails
that secure fence panels to rotted posts (top). This allows
intact fence sections to be removed and set aside for reuse as
replacement posts are installed (bottom).
Once we've set the fence sections aside for reuse, we dig
around the post to the depth of one shovel blade. If the post
isn't set in concrete, I then take the pointed end of my
wrecking bar and stab it into the side of the post a few inches
below ground level while my helper does the same on the
opposite side. We lever the post upward in unison, taking a
fresh bite with the bars as needed. If the ground is soft, we
use scraps of 4x4 as fulcrums between the bars and the edge of
the hole. If the base of the original post was set in concrete,
I sometimes rent an electric jackhammer to break the concrete
ball into manageable chunks (Figure 3).
Figure 3.When the original posts are set in
concrete, removing them takes time and may leave an oversized
hole that requires extra concrete to fill. Breaking up the old
base with a rented electric jackhammer saves time and
trouble.
The local frost line is at about 42 inches, but I've found
that setting post bases at a depth of 24 inches reliably
prevents any heaving. After cleaning up the hole with a
posthole digger and making it deeper if necessary, I drop in an
8-foot pressure-treated 4x4, renail the stringers, and fill
around the post with bagged concrete mixed by hand in a
wheelbarrow (Figure 4).
Figure 4.A replacement post is nailed to an
adjacent fence section and plumbed with temporary bracing as
site-mixed concrete is poured around the base (top). Bringing
the concrete up to grade protects the post from rot where it is
most vulnerable (bottom).
Other Repairs
If necessary, we'll also build new sections of fence to
replace any that are too damaged to reuse. Depending on the
pattern of the fence, I charge from $20 to $35 per linear foot
for this work. Instead of using prefabricated fencing panels, I
build replacement sections stick by stick, because that makes
it possible to follow the slope of the finish grade. Prefab
panels, by contrast, have to be "stepped down" to follow the
slope, which results in a much less attractive
installation.
John Wilderrepairs fences in Rosemount,
Minn.
