Although the term "green building" is relatively new, I've
been an environmentally conscious builder since the mid 1970s,
when I started a business building solar greenhouses and
sunrooms in eastern Rhode Island. My original one-man
enterprise has since expanded into three separate but closely
linked companies: RemodelWrights, a design-build green
remodeling business; SolarWrights, which installs solar
electric and solar domestic hot water systems; and Earth
Friendly Homes, which designs and builds new custom
homes.
I'm strongly committed to environmental building, but I'm also
a businessman. I've found that positioning myself as a green
builder is a sound business strategy as well as a way to do
work that I feel good about.
Energy-efficient ICF walls and
foundations are long lasting and use less concrete than
conventionally formed walls -- two traits that kick them into
the green category even though polystyrene and concrete aren't
obviously green materials.
What Is Green Building,
Anyway?
Basically, green building is a way for homeowners to minimize
the environmental impact of their home improvement and
construction projects. To qualify as "green," a project must
satisfy four key criteria:
* Reduced energy use. Green
buildings are frugal in their use of energy. This is
accomplished through proper design, a well-insulated building
envelope, and efficient appliances and lighting fixtures that
cut down on water and electricity consumption. Making the most
of natural daylight with thermally efficient and well-placed
windows and skylights not only reduces electricity use but also
enhances the quality of the living space. This is especially
important in northern areas, where natural light is at a
premium during the fall and winter.
House size is another important consideration. Not all green
builders would agree, but I believe that a green house
shouldn't be unnecessarily large. Even if it's very efficient,
a 10,000-square-foot house will consume a lot of energy and
material. In our design work, we emphasize comfortable but
modest-sized living spaces. With skillful design, even a small
house can be made to feel spacious.
* Energy production. Where
possible, green buildings use solar energy in place of oil,
gas, or utility-supplied electricity from non-green sources
such as coal and nuclear power. Depending on the situation and
the budget, this can mean using the sun for passive space
heating, providing domestic hot water with solar collectors, or
generating clean photovoltaic electricity.
* Providing a healthy indoor
environment. Green buildings avoid products and finishes
that outgas harmful chemicals, and natural or mechanical
ventilation provides good interior air quality.
* Environmentally friendly
materials. Finally, green buildings use materials with
at least one of the following characteristics:
-- they're made from recycled materials
-- they'll have a long and useful life with minimal
maintenance
-- they were manufactured without dangerous materials
-- they're made from sustainably harvested wood
-- they don't require a lot of energy to manufacture and
deliver
-- they can easily be recycled at the end of their useful
lives
Selecting Green Materials
It isn't always easy to tell whether a given material
qualifies as green. I've been active in the field for long
enough to have a good feel for this, but new materials are
constantly emerging. To keep up with them, I rely heavily on
the GreenSpec Directory, which is a nearly 400-page
guide to green materials from hundreds of manufacturers
(BuildingGreen, Inc., 800/861-0954,
http://www.greenspec.com). In addition to
product information, it includes guideline specifications for
everything from site work to doors and windows, interior and
exterior finishes, furnishings, and mechanical systems. We use
an extensive list of green products and materials -- the
following are some of our favorites:
Foundations and exterior walls. We're the regional
distributor for Reward Walls ICF wall systems, which have
worked well for us because they're easy for our carpentry crews
to install. When we're using a slab-on-grade foundation, ICFs
allow us to pour the walls and the floor at the same time,
reducing labor and pump-truck charges. The resulting concrete
walls are much more durable than stick-framed walls and have an
adjusted R-value of 33.
Floor framing and decking.
For spans under 16 feet, we use Boise Cascade All-Joist floor
trusses because they're cost effective and easy to use, and
they make efficient use of trees. For longer spans, we use the
Boise Cascade BCI 90XL Series joists. If we're making a
concrete floor heated by radiant coils, we pour a 4-inch
concrete deck over the BCI joists, using galvanized corrugated
steel decking. When we make a traditional floor system, we use
3/4-inch tongue-and-groove AdvanTech subflooring. Because our
houses are very tight, we use non-solvent-based GE-400L
subfloor and deck adhesive to avoid possible outgassing.
Insulation. Bonded Logic
UltraTouch insulation is a batt insulation made from scraps
produced in the manufacture of blue jeans. It's easy to
install, and unlike fiberglass it doesn't cause itching or
respiratory irritation. It's more expensive than fiberglass,
but we think it's worth the extra cost.
Cotton batt insulation made from
recycled blue-jean material has a thermal performance similar
to that of fiberglass, although at a higher cost.
Exterior siding. For lap
siding, we use WeatherBoards fiber-cement siding from
CertainTeed. Natural wood shingles are popular in our coastal
area, and here we use white cedar shingles from Maibec, which
are certified by the Forest Stewardship Council (FSC) as coming
from sustainably managed woodlands.
Outdoor decks. The framing
lumber we prefer is PreservePlus from Chemical Specialties,
Inc., because it's pressure treated with a safe, arsenic-free
preservative. For the decking itself, we use Trex or SmartDeck,
both composite materials made largely from recycled plastic and
reclaimed hardwood sawdust. For some high-end projects, we use
Pau Lope decking, which is a sustainably harvested, naturally
durable hardwood from Brazil.
Interior paint and stain. On
painted interior surfaces, we use Dulux's LifeMaster 2000
low-VOC paint. We also use water-based EF series wood stains
from General Finishes.
Finish floors. For projects
with poured radiant floors, we use a variety of ornamental
flatwork techniques to provide a stone or tile effect, which we
then finish with Patina Stain from QC Construction Products. We
also use a range of other flooring products, including natural
cork, linoleum, bamboo, and several types of recycled or
certified wood.
Cork floor tiles are glued to the
subflooring with a non-solvent-based adhesive. In addition to
being durable, warm, and resilient underfoot, cork is
considered a green material because it's sustainably harvested
from the bark of a European oak tree.
Decorative concrete floors, finished
with a low-VOC stain, meet several key green criteria: They're
highly durable; they minimize use of material by serving as
both structure and finish; and they can absorb and retain heat
in passive solar applications.
Design
We try to incorporate solar energy strategies into our
projects whenever practical. When the site meets the
requirements for solar energy, we incorporate passive solar
energy strategies as well as solar thermal systems and solar
electric systems (photovoltaics).
Planning ahead. In some
cases, the project budget doesn't allow us to install the solar
equipment at the time of construction. We will incorporate the
solar equipment in the design and label it "future solar
collectors" or "future photovoltaic modules." Before closing up
the walls, we run insulated copper tubing or install a wire
chase from the attic to the basement to make it easier to
install the equipment at a later date. More often than not, the
customer will "find" the extra money to have us come back and
finish the installation.
Thoughtful design is a key element of
green building. The orientation of this waterfront house, built
with ICFs, funnels summertime breezes into the living space
through the doors and window that face the angled deck. In
winter, the attached garage blocks the prevailing winter wind.
The passive solar sunspace heats the whole house on sunny
winter days; a separately zoned radiant floor provides
supplementary heat in cloudy weather.
Business Advantages
One of the biggest benefits to positioning yourself as a green
builder is that it moves you into a profitable niche market
where there is relatively little competition. Instead of
competing with every other all-around builder or remodeler in
the area for customers who are shopping for a low price, you're
dealing with people who sought you out because they want the
specific products and services you provide.
Working with customers. I've
found that green customers are generally a pleasure to deal
with. They tend to be thoughtful, well-educated people who are
eager to work with a builder who shares their values, and they
are often willing to pay the extra costs that an
environmentally friendly project may involve. You probably
can't fake a green commitment, though: Your customer will
quickly figure out your ruse, and the trust you'd hoped to
establish will be gone for good. In other words, you're
unlikely to succeed as a green builder unless you're also an
environmentalist.
One way to show customers that you "walk the talk" is to run a
clean and green building site. We take pains to prevent erosion
and protect existing on-site trees (see
"Saving Trees During
Construction," 9/01). Instead of mixing all our job-site
waste in the dumpster, we separate glass, plastic, metal,
cardboard, roof shingles, and reusable wood. Our town's
recycling center is near our office. When I stop by job sites
to check on progress, my crews load my truck, and I stop at the
recycling center on the way back to the office. This takes a
little extra time, but it also reduces the number of dumpsters
needed on our jobs.
Spreading the word.
Marketing and advertising are two different things. Because of
the success of our marketing efforts, we have not needed to
spend money on paid advertising. That's partly because word of
mouth seems to travel readily through the green community, but
also because green building generates some publicity of its
own. Green projects are often unusual enough that local
newspapers and other media will cover them as news, providing
exposure that's more effective than paid advertising.
Local newspapers and other print media
often see green building projects as news, increasing name
recognition and generating favorable word of mouth at no
cost.
Certification programs. Some
state and local governments sponsor programs that allow
builders to certify that their houses or remodels comply with
specific green criteria. A list of these community green
building programs is available from the U.S. Department of
Energy at
http://www.sustainable.doe.gov/buildings/gbprogrm.shtml;
the site also contains lots of additional information on green
building practices.
There aren't any local certification programs in our area, so
we haven't been able to participate so far. But we do take part
in the Energy Star program, which has some similar marketing
benefits. Because most green clients are concerned about energy
efficiency, they often start their search for a builder with a
list of local Energy Star builders. If the customer installs
Energy Starapproved appliances and the completed project
passes a blower-door test, the homeowner is eligible for up to
several thousand dollars in rebates.
Bob Chew'scompanies are located in Barrington,
R.I.
