- Q.I build custom homes in a
northern (heating) climate. My clients want tight,
well-insulated homes — we use cellulose and
often spray foam — but many also want a
wood-burning fireplace. Is it possible to have a
traditional hearth in a modern, tightly insulated
home?
A.Kevin Stack, a certified
home energy rater in Syracuse, N.Y., responds:
The traditional open-hearth fireplace has a lot of
charm and is often at the top of the typical
new-home buyer's wish list; it is also inefficient,
creates a break in the thermal envelope, and
generates both indoor and outdoor air
pollution.
For these reasons, the energy codes in many
states — including New York's Energy
Conservation Construction Code (102.7) —
require that solid-fuel fireplaces be installed
with tightfitting noncombustible fireplace doors to
control infiltration losses. New York's building
code also requires factory-built and masonry
fireplaces to be equipped with an exterior air
supply to assure proper fuel combustion, unless the
room is mechanically ventilated and controlled so
the indoor pressure is neutral or positive.
Unfortunately, these requirements can be both
expensive and difficult to implement —
while providing limited benefits.
Still, here in the Northeast, I've found that
the aesthetic value of a masonry fireplace is
strong enough for many buyers to be willing to
overlook these concerns. So when homeowners want a
conventional fireplace, my first recommendation is
that we mimic a traditional-style hearth but
install an EPA-certified fireplace insert. If they
demand the real thing, we build them a Rumford with
tightfitting glass doors, provide the required
makeup air, and advise them of the problems and
limitations they may encounter.
