by Paula and Steve Hagar
SIDEBARS:
Green and
Affordable - Casas de Don Juan
Green
Craftsmanship- Milburn House
Green building doesn't have to be unusual
— in fact, most elements of green building
are invisible and cost no more than standard
construction.
A decade ago, we were building commercial high-rises in
Dallas, and anything under ten stories was a small job. When
our son was diagnosed with environmental illness in 1990, there
weren't many doctors who had even heard of such a thing. It
turned out that many of his debilitating allergic sensitivities
were reactions to common building products, including solvents,
adhesives, petrochemicals, and resins. We knew that we needed
to make some changes, both personally and professionally, but
we didn't know what they would be. This was all new territory
and, as professional builders, we needed to remain economically
viable.
Today, along with some partners, we specialize in designing
and building ecologically responsible custom homes, commonly
known as "green building." Learning how to do this successfully
has been an intensive learning process and a rewarding change
in many ways.
Over the years, we have built or assisted with just about
every type of alternative construction imaginable, but our
mainstay has been perfectly average-looking houses. We recently
won a local award for energy-efficient low-cost housing as
well. Every one of these houses somehow fits into the "green"
category.
What's Green Building?
When people ask what makes a home "green," we have to answer,
"It depends," because there's no one right answer. In the
narrowest sense, green building is concerned with minimizing
the environmental impact of construction from site development
and procurement of materials all the way to the safe disposal
of the building at the end of its useful life. In the widest
sense, green building is about sustainability. Essentially,
sustainability is the art and science of providing a healthy
environment for ourselves and future generations while
maintaining a viable economy in the process.
Regionally
appropriate. A green house in the Northeast might
not look like a green house in the Southwest, but similar
principles will apply. Because green building strives to be a
"whole-system" approach, the principles outlined below are
interrelated. In fact, if you examine any one of them closely
enough, you'll eventually get to all of them.
Green building is, at the core, a design challenge. There is
no formula to determine what approach is most appropriate for
any particular site, but you can always arrive at a suitable
solution on the basis of these principles. And different
clients will have different considerations they'll want to
focus on. Ron Jones of Sierra Custom Builders summarized this
well in a recent NAHB publication, saying, "No one builder can
do everything, but everyone can do something. Recognize the
opportunities and then customize your efforts to match your
situation."
Make the least change for the
greatest effect
For most buyers, budget considerations are a reality. Green
building doesn't have to be more expensive - in fact, with
careful planning, it can produce savings. Our estimator, Mike
LeJeune, always explains to clients (and reminds us), "Green
building isn't about possibilities, because the sky is the
limit. It's about quantifying a specific benefit for a specific
cost. Our job is to identify and prioritize these design
changes to produce the greatest benefit for the greatest number
of people."
Energy Efficiency
Energy
efficiency is probably where green building receives the most
attention, and it's a great place to start. It's the least
controversial aspect, and the environmental benefits of reduced
energy consumption are well publicized. Best practices for
insulation, ventilation, and energy-efficient appliances have
all been extensively researched and documented, and most
builders already know something about the subject.
Incorporating solar gain is often feasible and almost always
cost-effective, although this is a feature that should be
designed carefully.
Does it pay? Ecological concerns aside, it
just makes sense to build a house that's inexpensive to heat
and cool. Reduced operating and maintenance costs can generally
offset the up-front expense of higher-efficiency appliances and
improved thermal performance. Clearly, there is a point of
diminishing return; in harsh climates super-insulation and
heat-recovery systems may make sense; in temperate climates
they may not.
For some clients, no increase in initial cost will be
acceptable; others will see five years as a reasonable payback
time, and for yet others, the extra 1% or 2% in the purchase
price of the house is simply not a concern. What constitutes a
reasonable return on the investment depends on many factors,
including the client's preferences about indoor comfort.
Increased
comfort For
example, radiant heat is a little more expensive to install
than hydronic baseboard and a lot more expensive than
forced-air, but we don't have any trouble selling it. Along
with the increased efficiency, clients really appreciate the
clean, quiet comfort.
While the individual energy savings of each family may not
seem like much, the collective result can be enormous. Just
remember that there is a balance between energy efficiency and
comfort; a home isn't an engineering project -- someone has to
live there.
Resource Efficiency
The criteria for effective use of natural resources are hotly
debated and will surely evolve as we learn more. Careful
material selection is certainly a large part of resource
efficiency; some widely accepted starting points include using
materials with recycled or recyclable content, minimizing the
use of materials that demand high inputs of energy in the
course of their production, and eliminating materials that
create unacceptable levels of pollution during either their
manufacture or disposal. Here in the Southwest, that means
avoiding vinyl siding, fiberglass insulation, asphalt roofing,
and carpet, and substituting stucco, adobe, straw, saltillo
tile, and metal roofing. In other parts of the country, other
materials will make more sense; for example, cedar siding or
brick might be the best choice if it is locally produced.
Recycled or reclaimed materials are also right at the top of
the list, as are sustainably harvested lumber and materials
that can be recycled or reused at the end of the building's
useful life.
Materials that make efficient use of abundant and renewable
resources are preferable, so we're great fans of engineered
wood products. Wood I-joists, trusses, and a variety of
engineered beams all provide a lot of design flexibility while
minimizing the use of valuable or - in the case of old-growth
forests - irreplaceable resources. As the glues and binders are
improved for higher performance and lower toxicity, we'll like
them even better.
Quality and durability are primary considerations for
material selection. Using good materials properly isn't just
good business, it's also part of green building.
Look at the true cost, not the
price. Green building incorporates a wider view of
the construction process, looking beyond the price tag and
examining the hidden environmental costs of a material. For
example, adobe and concrete might both be used for the
construction of exterior walls, and the installed price per
square foot for each material might be the same. But if you
consider all of the natural resources used to produce and
deliver each respective material to the site, there is a big
difference. The relative amount of resources consumed to
produce and deliver a particular product is referred to as the
"embodied energy" of that material.
You'll often hear environmentalists tout the benefits of a
particular material on the basis of low embodied energy, but
don't be misled. For example, concrete is often criticized for
having high embodied energy, but when you figure in the useful
life of the material, it can come out as the best choice in
certain applications. In every instance, green building is a
design challenge in which decisions are made by looking at the
larger picture.
Does size count?
There are those who say a large luxury home can't fit the
criteria of "green." We disagree. The fact is, the client is
going to build the house anyway. We're here to help them get
the very best house they can, with the greatest value, for the
best price. We have shown clients how they could easily work
with 7,000 square feet when they came to us with drawings for a
home twice that size. On one such project, we designed the
building so that, after two years, the owners have yet to pay
an electric bill, pay nearly nothing for gas heat (in a
6,001-degree-day climate), and the only well water they use is
for drinking -- the rest comes from rainwater catchment, which
is then reused for irrigation. Sure, it's a big house, but it
was also built from sustainably produced materials, it's more
energy- and resource-efficient than most tract homes, and it
will last longer, too.
Minimize
waste We work
hard to minimize waste -- it's one of the most expensive costs
on the job. You pay at least five times to create waste: Once
to buy the material, once to turn it into scrap, once to clean
it up, once to haul it, and once to landfill it. But some
waste, like packaging, is unavoidable.
The most productive place to minimize waste is at the
drawing board. Attention to detail during design saves costly
mistakes. This is also the chance to take advantage of
industrial production; if we're working with lumber and sheet
goods, basing the design on a 4-foot module can save a lot of
time and money, but if we're working with straw bales, we'd
better be thinking in increments of 3 feet.
On each site, we set up recycling areas for construction
waste. Trash is sorted into four bins: metals, plastics, and
paper, which are all recyclable, and trash that must be
landfilled. Next to that is the wood pile, which we try to
reuse until it disappears. Whatever is left can be donated for
firewood.
It doesn't cost a bit more to do this, and in fact we
probably save money, given the cost of tipping fees. Employees
are uniformly enthusiastic about this -- it's a fun game to see
how small the trash pile can be, and it's easier for everyone
to do a better job next time when the mistakes don't just
disappear into the dumpster. Subs get enrolled in the program
fairly quickly, and if they don't, we remind them that it's in
their scope of work.
Land
use Integration
of a structure with its environs is a key component of green
building. By situating a house thoughtfully, many benefits can
be realized. Solar gain, reduced excavation with minimal
disturbance to the site, and preservation of existing trees are
all cost-effective advantages.
Regionally appropriate landscaping can be used to support
existing wildlife with beautiful results and little additional
expense. Through careful design and plant selection you can
conserve water in almost any climate. Deciduous trees can help
with shade in the summer while admitting sunlight for solar
gain in the winter. Erosion control is required in many parts
of the country; with a little extra effort this can be turned
into landscape-enhancing water catchment (see photo,
below).
| Rock gabions help slow runoff for
erosion control and water catchment, both critical
concerns in the arid Southwest. |
Urban infill can combine the environmental benefit of
efficient land use with economic opportunities by taking
advantage of existing infrastructure, improving neighborhoods,
and in some cases offering low-cost or subsidized housing to
clients who might not otherwise be able to afford a home.
Healthy House
It has been
suggested that the quality of the indoor environment is not a
primary concern of green building, but we disagree. In our
opinion, it's impossible to approach green building without
including the health of the occupants.
Modern materials along with
tighter construction have resulted in legitimate concerns about
indoor air quality. The need for effective ventilation is well
documented and should never be neglected. Builders routinely
subject new homeowners to a toxic "chemical soup" as carpets,
paints, adhesives, and synthetic materials outgas into the
indoor atmosphere. Anything you can do to improve the indoor
air quality while maintaining thermal performance is good,
including the use of nontoxic and low-VOC materials. If you
have any doubts about the materials you use, read the
MSDS.
Why Build Green?
We got into green building for personal reasons back before a
lot of the recent technology was worked out, and we had a slow,
expensive learning curve. But a lot has changed in ten years,
and a tremendous body of knowledge is now available. New
materials are being invented all the time, and the reasons to
get involved are better than ever.
At the 1999 NAHB Green Building Conference, then-NAHB
President Charlie Ruma declared, "The future of home building
is green building." The demand is there, and so are the
profits. Many major metropolitan areas, including Albuquerque,
Atlanta, Austin, Boulder, Denver, Scottsdale, parts of
California, western Washington, and northern Maryland, show
enough interest in green building that HBAs are being formed
specifically for green building, with state and local
government agencies becoming involved, too.
We may have to,
soon As the
population increases and resources become scarce, green
building has taken on greater importance, and has become a
matter of public policy in some parts of the country. Many
cities and states are working on sustainable development plans,
and some have active programs in place. For example, Austin
Energy has created a Green Building Program in cooperation with
the city of Austin and nearly 200 local architects, builders,
contractors, designers, suppliers, and related tradespeople.
This program has served as a model for many other programs
nationwide.
As government officials at all levels realize the benefits,
they are increasingly encouraging green builders, and in some
parts of the country, incentives are available. Federal support
in the form of information and research is coming from the U.S.
Department of Energy, the EPA, HUD, and
government/private-sector partnership initiatives such as PATH
(Partnership for Advancing Technology in Housing;
http://www.path.org). PATH is described as
"a voluntary initiative that seeks to accelerate the creation
and widespread use of advanced technologies to radically
improve the quality, durability, environmental performance,
energy efficiency, and affordability of our Nation's
housing."
Benefits to the builder. Green building isn't
altruistic, as there are definite advantages for the builder.
Tom Estes of the California Integrated Waste Management Board
states, "Building green can minimize the impacts of development
on the environment and reduce the consumption of natural
resources over the building's life. This benefits the
contractor by differentiating him from the competition and
providing more value for his customers and results in more
demand for his product. Additionally, a builder with a
reputation for being green will usually have a better image
within the community."
Richard Dooley, environmental analyst with the NAHB Research
Center, observes, "By incorporating environmental issues into
the home building process - from site design to hand-off to the
homeowner - builders and developers have found that they can
build profitable homes that benefit the environment and the
homeowners."
Benefits to the
buyer By becoming
a green builder, your clients can enjoy health benefits, more
value for their money, reduced operating costs, a lower overall
cost for their house over the life of the building, and in many
cases, a higher level of perceived quality. Lenders are
beginning to realize that energy efficiency and careful
construction make good economic sense, and are beginning to
factor those potential savings in as they qualify borrowers.
For example, Paul McCutcheon of Old Kent Mortgage in Austin,
Texas, says, "Whatever your budget, whatever your style, you
can enjoy the benefits of a green home." Fannie Mae is working
on its own Housing and Environment Initiative to develop
mortgage products for energy- and resource-efficient housing.
Fannie Mae offers several "green mortgages" that provide
incentives for the design, construction, and purchase of homes
that use resources more efficiently. These mortgages generally
take the projected energy, water and resource savings that a
green built home offers and add them to the home buyer's income
for the purpose of qualifying for the home, giving the borrower
greater buying power. Fannie Mae has also developed a consumer
guide for buyers of green homes. (Home Performance Power:
Fannie Mae's Guide to Buying and Maintaining a Green Home
can be ordered by calling 800/471-5554 and asking for
publication number HI274.)
Getting Started in Green
Building
A lot of ink has been used trying to define what's green and
what isn't. The "greener than thou" attitude helps nobody, and
trying to force clients into anything is generally
unproductive. We'd rather see builders start wherever they are,
incorporate as many improvements as they can, and then
continually educate themselves and their clients as time goes
by.
If you can build a comfortable, attractive, energy-efficient
home that fits your client's budget and outlasts the mortgage,
you are more than halfway there. Then you can focus on nontoxic
materials, sustainably produced or recycled materials, indoor
air quality, waste reduction, embodied energy reduction,
wildlife ecology and habitat preservation, water conservation,
and lower building operation and maintenance costs. An
alternative energy source (such as solar, wind, photovoltaic,
or geothermal power) is often an option, especially in rural
areas, and as the technology improves, the prices are coming
down.
Savings by
design Your
efforts as a green builder start with the design. At the 1997
Green Building Conference in Austin, Texas, architect Sym Van
der Ryn said, "Every dollar you spend at the drawing board is
worth ten dollars on site." In our experience, he was being a
little conservative, but the point is well taken.
We try to design our buildings so that the client always
receives the maximum benefit possible. For example, the roof
can do more than keep the house dry. It can also be used for
rainwater collection, and the roof overhang can work with the
windows to optimize solar gain in the winter and shading in the
summer. Windows can be used for view, natural lighting,
ventilation, and solar gain. Carefully designed thermal mass in
walls can help optimize a heating system while effectively
attenuating noise from outside the building.
Mary McLeod, residential specialist with Austin Energy's
Green Building Program, explains, "Green building has nothing
to do with style and very little to do with money. It's hard to
recognize, because it's hidden in the design process of
building the right house for your site."
Profit from
savings Through
careful design and by trying to make every component of the
structure perform several functions, you can find unexpected
savings. Those savings can be reinvested in the project, your
employees, and your company. We try to work with dimensions
appropriate to our materials to minimize waste. Establishing
design clarity with the client early in the process saves
mistakes, changes, and unnecessary costs. Cooperation with the
subtrades during design is always a good idea; these guys are
experts in their field, and they can often suggest materials,
methods, and design modifications that benefit everyone.
Paula and Steve
Hagar work with Sustainable Building Systems, an
alternative-construction technology and design corporation, and
Living Structures, an environmentally oriented design/build
cooperative in Santa Fe, N.M.
For More
Information |
P.O. Box
1088Austin, TX 78767512/505-3702These folks are among the
foremost authorities in green building, and a
premier source of information. Their work has
served as a model for others
nationwide. Built Green
Coloradoc/o HBA of Metropolitan
Denver 1400 S. Emerson St. Denver, CO 80210 303/778-1400 California Integrated Waste
Management Board1001 I St. Sacramento, CA
95812 916/341-6000 This first-rate website is a
great place to start. Maryland Department of Natural
ResourcesEducation, Bay Policy, and
Growth Management Tawes State Office Building,
E-2 580 Taylor Ave. Annapolis, MD 21401 410/260-8710 | NAHB Research Center400 Prince George's
Blvd.Upper Marlboro, MD
20774800/638-8556 Partnership for
Advancing
Technology in Housing470 L'Enfant Plaza S.W
Suite 7110Washington, DC
20410202/708-4277 Other Websites of
Interest:
Energy Efficient Building
Association Environmental Building
News
Oak Ridge National Building
Technology CenterU.S. Department of Energy,
Rebuild America
Program
U.S. Environmental Protection
Agency
Energy Star Homes Program
