Green Building For Profit - Sidebar
Green and Affordable: Casas de Don Juan
Both of these three-bedroom, two-bath, 1,384-square-foot
homes were built in cooperation with the Santa Fe Community
Housing Trust as part of an affordable housing program. The
construction cost was low by local standards at $80 per square
foot. The relatively small lots are best described as "infill"
in an old neighborhood that is currently being revitalized. But
low cost doesn't have to mean low quality - these houses were
recently awarded the Parade of Homes Judge's Choice Award for
Best Home under $250,000.
Mature trees on the small lot
were carefully preserved, and rainwater is used to
support landscaping and wildlife. Notice the shadow
line under the portal, which has been carefully
designed to admit daylight without overheating the
interior.
Despite the relatively low cost, the houses boast excellent
interior and exterior finishes (tile interior throughout,
acrylic-fortified stucco exterior). Natural lighting, good
ventilation, and a thoughtful floor plan help to make the best
use of space. Thermal performance was emphasized throughout
design and construction, with a high-efficiency hot water
heater and boiler, radiant heat, double-glazed windows, and
careful attention to weather sealing. Fly-ash was incorporated
into the concrete mix to reduce the Portland cement content in
the slab, which also acts as thermal mass to retain and
modulate solar gain. The 2x6 walls were insulated with
wet-spray cellulose and R-5 foam sheathing. A blower-door test
was conducted at the end of the job to evaluate the envelope
and to determine ventilation requirements.
Careful construction,
thoughtful design. Mature trees on site were
protected carefully, and stone from a pre-existing rubble
foundation was reused for the yard wall and landscaping. Water
catchment was integrated into the grading and drainage plan in
the form of a pond, which supports regionally appropriate
landscaping and gives birds a place to get a drink (a rare
treat in the desert). The architect, Greg Walke of WOA, Inc.,
made sensitive use of locally available materials to retain the
regional character of Santa Fe without breaking the budget, and
provided for shade, privacy, natural lighting, and optimal
placement on the lot (see photo below). He also specified
low-VOC finishes and polystyrene products that were
manufactured without CFCs or HCFCs.
This project worked out well for everyone -- us, the city,
the new homeowners, and their neighbors. By using the existing
infrastructure, infill housing saves money, conserves
resources, and can provide housing for those who might not
otherwise be able to afford it. These houses were built within
a block of each other in an older, traditional neighborhood.
During construction, several of the residents stopped to thank
us for helping to improve the neighborhood. It's hard to put a
price on that.
-- P.H. and S.H
