Building a Timber Barn, continued
The Frame
To achieve the right "look," there's no beating the
tried-and-traditional materials. My frames are built from
locally harvested and milled eastern white pine, which arrives
at the site still green. Except for rare cases when the lumber
comes from an unfamiliar sawmill, all of our framing stock is
rough-sawn to full dimension. A 6x6 is literally 6 inches
square, and my joists measure a full 2½ inches.
Occasionally, but not often, I'll have a client who wants the
interior surfaces planed smooth, which requires a simple
request to the sawmill and a material upcharge to the
customer.
Walls are framed with 6x6 posts on 6- to 8-foot centers. We can
spread or squeeze the layout to suit the overall wall length.
The posts are tied at the top with a continuous 6x6
lintel.
Typically, we work with 12- to 14-foot-long posts and build a
story-and-a-half balloon-framed wall with a level lintel around
the full perimeter (Figure 4).
Figure 4.The second-floor joist ledger is
notched into the outside face of the posts, which
extend above the floor to create a knee-wall, adding
headroom and storage space to the "loft." The posts are
united with a continuous 6x6 lintel that carries the
rafters. |
We lay all the posts on sawhorses for gang-cutting. Because
the lengths are nominal and rough from the mill, the first task
is to square-cut one end. At the ceiling level, typically 8
feet, we notch the exterior face of the posts to let in a 2x10
ledger board (Figure 5). The floor joists rest on that ledger
and run to the center of the building span.
| Figure 5.Posts are notched for a 2x10
ledger and 4x4 purlins before standing. This barn is
being raised over a full foundation on an
engineered-lumber deck frame. Pine floor boards will
cover the plywood subfloor. |
Between the mudsill and the lintel, we notch the posts to
fit a 4x4 wall purlin. The purlin is typically located around 4
feet high on the wall and establishes the common windowsill
height. This height provides uninterrupted wall area for
installing a perimeter workbench.
No headers needed. With both
the lintel and the joist ledger carrying overhead loads,
individual window headers are unnecessary. Instead, we
reinforce the opening cutouts with 4x4 jambs and a butt-fitted
4x4 header, both for appearance and to provide solid nailing
for the exterior trim. We often use recycled divided-light wood
sash in new pine frames (Figure 6). Not only does this provide
the barn with the right look of Yankee make-do frugality, but I
can get the sash free from a replacement window contractor.
Figure 6.As a touch of authenticity, the
author often uses recycled wood window sash and
installs them in site-made pine frames. |
Sometimes we let the posts run long and cut them in place.
The clients may still be undecided about the second-story
windows, preventing us from predetermining the required opening
height, or the top of the foundation may be so uneven that it's
easier to stand the posts and trim the tops to a level
line.
Girders. At the center of the
second floor, we typically use a steel I-beam strongback to
break the span. While steel isn't a traditional barn-building
material, it allows me to eliminate some of the posts required
by a sawn wood girder. It's also easier for us to work with
than an engineered wood beam, because we don't need multiple
layers or metal joist connectors. Instead, the floor joists are
nailed to a 2-by cleat set on the bottom beam flange and are
secured by a 16d common nail driven down through the top flange
(Figure 7). Predrilling the steel flange doesn't take much
effort; I have a helper do it. The end of the joist is notched
around the top flange and is slightly higher than the beam, to
allow for eventual drying shrinkage. Otherwise, the flooring
will develop a hump over the girder. To minimize the appearance
of the I-beam, we can easily veneer the sides and bottom with
1-by pine.
Figure 7.At center span,
joists are carried by a steel I-beam and rest on a 2-by
pine cleat that's nailed to the bottom flange (left).
The top edge of the joist is notched to clear the top
flange and allow for shrinkage settling, so that a lump
doesn't develop over the beam in the floor upstairs. A
nail driven through a predrilled hole in the flange
captures the joist to prevent
roll-over. |
We set the 2½ floor joists on 2-foot centers. To
create a stairwell, we leave one joist out, usually at the end
of the run. After installing short, diagonal braces between
every post and the 2x10 ledger to help stiffen the frame, we're
ready to install the 1x10 shiplap subflooring. Alan maps the
layout from the center of the deck to ensure that a single
board will bridge the steel I-beam (Figure 8). Beginning at one
side of the deck, the first board is notched around the posts,
and the rest of the floor is laid with butt joints staggered
over joist centers. Flooring goes quickly, face-nailed with
3-inch common gun nails, two in the field and three at the
butts.
Figure 8.Flooring layout begins at the
center of the span to ensure that a single floor board
covers the top flange of the steel beam and can be
nailed down at its edges. The center of the board
eventually comes into full contact with the beam as the
joists dry and shrink. |
Next, we set the 6x6 lintels, which are scribed in place
over the posts, then notched to let in the posts (Figure
9).
Figure 9.The posts are all cut to an equal
height and are captured by notches in the lintel beam
(top). The lintel is first scribed in place (above
left), then flipped over and kerfed with a circular saw
set to cut 1 inch deep. |
