For more than 50 years, and in several organizational forms,
APA The Engineered Wood Association has provided
technical leadership in the manufacture and use of structural
wood composites. During this period, APA has published
countless technical directives for a host of wood composites,
including plywood, OSB, glue-laminated beams, laminated veneer
lumber, and, most recently, wood I-joists. APA has now
synthesized this wealth of information into a handy compendium.
The APA Engineered Wood Handbook edited by Thomas G.
Williamson, P.E. (McGraw-Hill, 2002; 800/722-4726,
http://www.construction.com; $115) is a
solid reference tool prepared by the Technical Services staff
of APA.
I have to warn you, though: This chunk of a book is dry. How
dry is it? Let's just say that within ten minutes of opening
it, I thought the relative humidity in my office had dropped
60%! But in all fairness, no one purchasing this book is
looking for an ocean of fun. The style will be familiar to
anyone who has used APA product guides and standards; it's
technically comprehensive and rich with hundreds of useful
illustrations and tables. At 750 pages, it's meaty, but the
6-by-9-by-3-inch shape is easy to hold. At first, I was
concerned that the thick profile would be awkward to use, but,
with a little coaxing, the hardcover book remains open on your
desk while you work with a computer or calculator.
The handbook is nicely organized into 12 chapters that provide
a variety of information. Although much of it is basic and
helpful to practitioners, the dialogue extends far and delivers
an abundance of complex design guidelines required only by
engineers. For example, the handbook clearly describes various
panel products and explains how they're used, with specific
advice for handling materials and protecting yourself. Fastener
schedules are provided, and tables and figures generously
illustrate application details. Grade stamps are explained, and
appropriate spans for a broad range of installations are
recommended.
But then, exit designer wanna-bes and enter professional
engineers. The level of complexity turns to a discussion of
mechanical properties. This is heavy stuff -- you could easily
pull a muscle reading page upon page about capacities,
adjustment factors, and allowable stress and strain. All this
leads to a set of complicated design examples where engineers
get to practice a multipage calculation or two.
The treatment is generally consistent and appropriate, chapter
to chapter. Builders, specifiers, designers, and engineers all
get what they need in a functional format, as seen in the
chapter listing:
1. Introduction to Wood as an Engineering Material
2. Wood Structural Panels
3. Wood Structural Panels in Structural Components
4. Structural Glued Laminated Timber
5. Prefabricated Wood I-Joists and Engineered Rim Board
6. Structural Composite Lumber
7. Designing for Lateral Loads
8. Mechanical Fasteners and Connections
9. Treatments and Finishes for Wood
10. Fire- and Noise-Rated Systems
11. Fiber-Reinforced Polymer (FRP)Wood Hybrid
12. Designing and Detailing for Permanence
There are a few soft spots in this fruit. The page-numbering
scheme takes a little getting used to. Pages are numbered in a
"chapter.page" format, and chapter sections are numbered using
the same system. Therefore, you'll find installation details
for roof I-joists in section 5.10 on page 5.96. I quibble, but
this gets a bit confusing when you're looking for
cross-referenced topics.
There is no single performance standard for wood I-joists like
there is for plywood and OSB (oriented-strand board). APA is
trying to standardize the I-joist industry, but it's a battle.
Most manufacturers fear that standardization will convert
I-joists into a low-value commodity product like lumber. As a
result, APA certifies just 25% of the wood I-joists made. This
means that whenever you use engineered I-joists, rim boards, or
other proprietary materials, you have to use the specific
manufacturer's guidelines, not this handbook. This devalues
information like that found in Chapter 5 to general
interest.
My last criticism of this book involves topic selection. The
chapters "Fire- and Noise-Rated Systems" and "Designing and
Detailing for Permanence" are up to date and relevant to good
building practice, but they don't deal with engineered wood. On
the other hand, you might expect engineered wood products like
machine-stress-rated lumber, open-web joists, and roof trusses
to be covered, but they're not. These topics seem more
appropriate and should be included.
Overall, the publication is well balanced, providing a good
introduction to each topic. Practical discussions introduce
more complicated, analytical sections in a logical sequence. A
complete and useful index leads readers smartly to specific
topics.
The APA Engineered Wood Handbook consolidates a pile of design
guidelines under one cover. It's well done, fills a niche, and
is useful for residential and nonresidential building
construction. Although the book is most helpful to structural
engineers, it's also of value to serious builders and material
suppliers who want a handy reference for structural wood
composites.
Paul Fisette is director of Building Materials and
Wood Technology at the University of Massachusetts at
Amherst.
