Soffits and Overhangs
Soffit treatments seem to concern a lot of the contractors I
meet in the field. "How can I nail my fascia to that skinny
little piece of OSB?" is a question I hear a lot. The truth is,
there are several details that work, depending on the roof
profile you want (Figure 4).
| Figure
4. Many soffit profiles are possible with an
I-joist roof system. Shown here are dimensional lumber
rafter tails (left), a level soffit (middle), and an
I-joist used as backing for fascia
(bottom). |
One typical detail is to sister on dimensional lumber rafter
tails. You can also use plywood, an engineered rim board
material, or even another I-joist for fascia backing. To frame
a flat soffit, you can extend the birdsmouth cut to the end of
the joist, then attach 2x4 blocking for a soffit nailer. Just
about any traditional profile is possible with proper planning
at the design stage.
The rules for overhangs are straightforward. All the
manufacturers’ design guides show many details. One point
to remember is that if a birdsmouth cut has been made, the
maximum allowable overhang for any of the details is 2 feet. If
you want a longer overhang, use a beveled plate or sloped-seat
connector.
Gable-end overhangs.
Gable-end outriggers are framed by cantilevering dimension
lumber across the gable-end top plate, similar to stick-framing
techniques (see ).
Hips and Valleys
Hips and valleys are possible with wood I-joists, but the only
practical way to frame them is to use the field-adjustable
hangers mentioned above. The techniques are identical to the
methods mentioned earlier, except that when the hanger is
installed to the beam, the hanger must be skewed (Figure
5).
| Figure
5. Sloped-seat hangers can be skewed up to
45° for hip and valley jack rafters. Compound cuts
are not necessary; only the plumb cut needs to be
made. |
Although hangers can get expensive, one advantage of this
technique is that compound cuts are not needed on the jack
rafter ends. The only cut required is the plumb cut.
Header Details
Framing headered openings for skylights and dormers is also
straightforward. As with dimension lumber, the size of the
opening determines how many I-joists are needed to support the
header. If the header hangs from a single I-joist, you nail a
backer block (typically plywood) to the joist, then nail the
hanger to the backer block (see ). Double I-joists require a
filler between them — either plywood or dimension lumber
— and a backer block for the hanger. For really large
openings, it makes sense to use an LVL or Parallam beam to
support the headers instead of multiple I-joists.
