- Q.Why should the small amount
of moisture from a bath fan be a problem in a large,
well-ventilated attic? I find bath fans vented into the
attic more often than I find wall or roof caps, and, in
most cases, there is no problem.
A.The key words here
are "large, well-ventilated." Most attics today are
not as large as in the past, and many are not
well-ventilated. Rather than trying to establish
standards for those conditions, it is easier to
require that all fans be vented to the
outdoors.
I always recommend venting exhaust fans to the
outside. If you must vent into the attic, however,
fan discharge should never blow directly into the
insulation, nor should it blow against the roof
sheathing. If the discharge is brought a foot or
two above the insulation and blown horizontally
toward the middle of the attic so the moisture can
diffuse into the air before it hits a cold surface,
problems might be avoided. Most of the fans I know
of have no ducting at all and blow directly into
the insulation. While the amount of moisture from a
bathroom fan may be considered small, it can be the
"straw that breaks the camel’s back" in an
attic with marginal ventilation and numerous vapor
leaks.
