I've been a carpenter for more than 20 years, but I only
recently installed fiber-cement siding for the first time. When
JLC asked me to try out some of the portable tools for
cutting fiber-cement siding and trim, it was an opportunity too
good to pass up: a chance to check out the tools without
risking a bad purchase.
Cutting fiber cement with a circular saw blade is like
producing your own personal dust storm -- definitely not the
most pleasant environment to work in. I'm not afraid of getting
dirty, but fiber-cement particles are very small and especially
irritating to sinuses, skin, and eyes. So it's natural that
manufacturers would be keen on developing tools that cut
cleanly and quickly, without the dust.
Two Schools of Thought
Two types of dust-busting portable tools have emerged:
circular saws with a dust collection system and electric shears
that cut fiber cement the way aviation snips cut metal (see
Figure 1).
Figure 1.With a cutting action similar to that of
scissors, shears crush the material between hardened steel
blades. Replacement blades cost about $65, and makers claim
that the blades will last for about five 2,000-square-foot
houses.
Dust-collecting circular saws are similar to the circular saws
we use every day, with one major difference: The blade is
covered by a plastic shroud with an exhaust port that connects
to a portable vacuum. I tested Makita's 7 1/4-inch model 5057.
(Makita also makes a similar 4-inch saw, model 5044KB.)
Shears come in two platforms: large, relatively stationary,
guillotine types and hand-held portable shears powered by
electric drill bodies. I didn't test the guillotine-type
shears. They may well be the best tool for cutting fiber
cement, but unless you're a full-time siding subcontractor, the
$1,200 investment wouldn't be practical. I tested portable
shears from Kett, Snapper, and Porter-Cable.
Fiber-cement shears have their origin in the electric shears
used by sheet-metal fabricators. However, you can't use
fiber-cement shears to cut metal: The cutting head on
fiber-cement shears won't accept metal cutting blades, and vice
versa. If you want to use your shears for both materials, the
best option is to buy another cutting head designed for metal
($60 to $100) and swap the heads back and forth.
Makita 5057KB Dust-Collecting
Saw
Based on Makita's venerable model 5007 circular saw, the
5057KB dust-collecting saw looks similar to a typical
sidewinder except for the plastic housing enclosing the blade
(Figure 2). I found that the saw worked better in theory than
in practice. The blade enclosure quickly filled with dust,
reducing visibility, and retracting the guard was
cumbersome.
Figure 2.Makita has addressed the dust problem
with a vacuum-connected saw. A plastic housing encloses the
blade, capturing the majority of airborne
particles.
But perhaps my biggest obstacle to using the saw was that it's
a sidewinder, and I happen to be accustomed to wormdrives.
Switching platforms proved difficult for me -- a sidewinder fan
would probably be more comfortable with this saw. When a pin
securing the shoe fell out, rendering the saw unusable, I
happily set it aside. Despite my experience with the saw, it
produced an excellent cut. Plus, unlike the shears, the saw can
be used for cutting other building materials. The street price
is $222, without the diamond blade.
