Cutting Fiber-Cement Siding
Specialized power tools work well, but so does a simple circular saw blade
9 MIN READ
Cutting Fiber-Cement Siding, continued
Makita 721263-A Fiber-Cement Blade
When the Makita saw broke, I installed the four-tooth fiber-cement blade on my Skil wormdrive and went back to work. This blade is fantastic. Even when gang-cutting up to six pieces, it produced smooth, fast cuts (Figure 3). And while the work was dusty, the speed with which the saw cut made it bearable. Although Makita would probably discourage it, cutting an occasional piece of lumber wasn’t a problem. The blade has a street price of about $75.
Figure 3.Makita’s 71/4-inch fiber-cement blade works like a dream. The diamond tips and thicker kerf produce clean, efficient cuts, making it a favorite of the author.
Kett KB-392 Cordless Fiber-Cement Shears
This was my favorite set of shears overall. Although they cut slower than the corded shears, the convenience of cordless made up for the pace (Figure 4). When I first used them, the battery pack got in my way on longer cuts. Frustrated, I loosened the screws securing the cutting head and rotated it slightly, which produced a more effective and comfortable cutting angle.
Figure 4.These Kett shears cut more slowly than the corded variety, but the convenience of cordless made up for the slower cutting speed.
The 14.4-volt drill body ran for a long time, frequently going the whole day without swapping packs. I was grateful for the run-time, because the battery release was difficult. Kett’s cordless shears come with two batteries and have a list price of $420.
Kett KD-292 Electric Fiber-Cement Shears
The Kett KD-292 was my favorite set of corded shears. At 41/2 pounds, they were 1/2 pound lighter than the others. Although initially concerned that there was no variable-speed trigger, I soon discovered that didn’t matter (Figure 5).
Figure 5.Even though these Kett shears lack a variable-speed trigger and a belt hook, their 1/2 pound less of weight than the others made them the author’s favorite electric shears.
Controlling cuts depends more on how quickly the operator feeds the material and less on motor speed. But I did find one serious shortcoming with the KD-292: no belt hook. And because electric shears won’t fit in a standard drill holster, I often found myself looking for a convenient spot to set them down. It’s not a big problem while working on the ground, but it’s a major pain when you’re up on a scaffold. The tool has a list price of $230.
Kett KC-193 Electric Fiber-Cement Shears
The variable-speed KC-193 is an ounce shy of 5 pounds, making it among the heaviest of the shears, but I found that the motor was smooth and didn’t bog down, even with aggressive cutting. This Kett model includes a top-mounted belt hook and 2 additional feet of cord, but the additional weight, compared with Kett’s model KD-292, makes it more tiring to use. Because it lacks a rubber grip on the handle, holding the shears with sweaty hands proved more difficult than with other models (Figure 6). The tool lists for $260.
Figure 6.Kett’s more powerful electric shears have a belt hook, which their cheaper model lacks. But without a rubber handle or grip insert, they’re tough to hold on to.
Porter-Cable 6605 Cement-Siding Shears
Based on a new 1/2-inch drill body, Porter-Cable’s model 6605 is more comfortable to use than the other shears I tested. The belt hook can be mounted on either side of the drill for right- or left-handed use. The side-mounted belt hook keeps the drill oriented for quick and easy retrievals, compared with top-mounted hooks that allow the drill body to flop around (Figure 7). The belt hook also provides a convenient thumb rest, and rubber inserts in the handle add to its ergonomic advantage. Although this tool weighs as much as the heaviest shears, the additional ergonomic features and better balance make it easier to use. The Porter-Cable shears have a street price of $229.
Figure 7.Porter-Cable’s shears have better ergonomics than any of the other shears tested. The side-mounted belt hook is reversible for lefties and holds the tool in a more convenient position than top-mounted hooks.
Snapper Shears Steelhead SS-404
Because it came with the longest cord and had the most powerful motor, I expected this tool to be a real standout. Although I liked the 9-foot cord, the Milwaukee-built 7-amp motor performed only slightly better than the smaller motors found on the other drill bodies. The tool weighs almost exactly the same as the other shears (except for the single-speed Kett model KB-392), but the motor felt front-heavy and put extra strain on my wrist and forearm (Figure 8). The disappointing ergonomics were enough to make me reach for another tool.
Figure 8.Snapper’s motor runs smoother and quieter than the others, and a 9-foot rubber cord is a plus. Even with the nice features, the front-heavy design makes the tool harder to use.
Interestingly, Porter-Cable uses Snapper’s shear head on its fiber-cement shears, but adding P-C’s side-mounted belt hook, along with a more balanced drill, made using P-C’s model less strenuous. The street price for the Snapper is $279.
Snapper Whipper Snapper SS-414
Although it bears a strong resemblance to standard shears, the hook-shaped cutter makes this tool unique among the fiber-cement tools I tested. Designed for curves rather than straight cuts, the Whipper Snapper cuts tight radii for outlet boxes and pipes (Figure 9).
Figure 9.The Whipper Snapper’s unique cutter head makes tight-radius turns around pipes, vents, and electrical boxes. It works well, but such a specialized tool is probably meant only for siding subs.
I also tried some 90-degree turns for notching under a window; while the shears managed it, I’m more comfortable making that type of cut with a circular saw. The SS-414 definitely cut a tighter radius than the other tools, but it’s a little too specialized for me to justify the cost. My Rebel Rotozip spiral cutter, equipped with a tile-cutting bit, proved an excellent tool for tight-radius cuts and also has the ability to make plunge cuts, something the Whipper Snapper can’t do. Street price for the Whipper Snapper is $299.
The Verdict
My first experience working with fiber-cement siding taught me a lot. I found that the specialized shears all produce a decent cut and don’t make dust, but they cut more slowly than I’m accustomed to. I used my wormdrive circular saw equipped with Makita’s fiber-cement blade more than the shears, in spite of the dust. The quality of cut was better, and gang-cutting six pieces is obviously more efficient than cutting a single piece at a time. I’m sure my familiarity with the saw added to my reliance on it, but speed was also a big factor.
In an effort to increase my efficiency, I tried using a set of shears to cut two pieces of siding at the same time. I figured that, since two pieces of siding are about the same thickness as the 7/16-inch fiber-cement trim, which I was able to cut easily, cutting two pieces of siding shouldn’t be a problem. As it turns out, the trim is less dense than the siding. The result of my test was a spray of ball bearings spilling from a broken shear head.
I also found that my Rotozip spiral cutter with a tile bit did an excellent job of making curved cuts around vents, pipes, and electrical boxes, and that that little tool is more versatile than those designed exclusively for fiber cement.
For me, the best option for cutting fiber cement would be to combine effective dust collection with a wormdrive or miter saw. But for now, it looks like my old saw and a good dust mask are the way I’ll go.
Matt Moody is a carpenter in Cabot, Vt.
List of Manufacturers
Kett Tool Company 513/271-0333 http://www.kett-tool.com Makita USA 800/462-5482 http://www.makita.com Porter-Cable 800/321-9443 http://www.porter-cable.com Roto Zip Tool Corporation 877/768-6947 http://www.rotozip.com Pacific International Tool & Shear 800/297-7487
http://www.snappershear.comSnapper Shear
