The ongoing tug-of-war between the federal government and
the states over the legality of requiring private businesses to
act as de facto immigration-enforcement agencies took a new
twist in June when a federal district court temporarily blocked
Oklahoma from enforcing two key provisions of a 2007 law.
Under Oklahoma HB 1804 — also known as the Oklahoma
Taxpayer and Citizen Protection Act of 2007 —
businesses seeking contracts with the state would be required
to use the federal E-Verify system to check the eligibility of
all employees. The rule would also impose state tax penalties
on businesses that failed to verify the work-authorization
status of individual independent contractors working for
them.
Both provisions were scheduled to take effect on July 1, but a
consortium of state business groups challenged the law in
federal court, claiming that it conflicts with the federal
Immigration Control and Reform Act of 1986, which states,
“The provisions of this section preempt any state or
local law imposing civil or criminal sanctions (other than
through licensing or similar laws) upon those who employ, or
recruit or refer for a fee for employment, unauthorized
aliens.”
U.S. District Court Judge Robin J. Cauthron issued a temporary
court order in favor of the business groups, finding it
“substantially likely” that they will
ultimately succeed in proving that HB 1804 is in fact
unconstitutional.
A future hearing — for which no date has yet been set
— will determine whether the temporary injunction will
become permanent.
Other portions of the law have been in effect since November
2007. Among them are provisions that prohibit undocumented
immigrants in Oklahoma from receiving any tax-supported state
services and that make transporting or harboring undocumented
immigrants a criminal offense.
It’s unclear how the Oklahoma ruling will affect
similar state and local laws elsewhere, such as the Legal
Arizona Workers Act — currently undergoing a separate
legal challenge in a federal appeals court — and Local
Law 52 in Suffolk County, N.Y., which requires contractors
doing business with the county to affirm that none of their
workers are undocumented.
Even less clear is whether Congress will ever step up to the
plate and pass a comprehensive immigration-reform act. Until
that happens, says NAHB immigration policy specialist David
Crump, the “emerging patchwork of confusing and
conflicting state and local laws” will continue to be
a source of frustration and anxiety for business owners.
“It’s a difficult situation,” Crump
observes, “because it puts employers at risk of
violating federal laws, particularly antidiscrimination
laws.” — Jon Vara
Green Goes Mainstream in
California
California has moved to cement its reputation as the
nation’s greenest state by releasing a preliminary
version of the nation’s first comprehensive green
building code — a move that, given the size of the
state’s housing market, could eventually lead to a
proliferation of similar state codes elsewhere.
Under the expected time line, a published version of the new
California Green Building Standards Code will appear before the
end of 2008, to be followed by a 180-day public comment period.
After that — probably by July of 2009 — the
code will take effect as a voluntary standard, becoming
mandatory in January 2011.
The new code sets standards for sustainable sourcing of lumber
and other materials; mandates the use of low-VOC paints,
adhesives, and coatings; and imposes new restrictions on water
and energy use. The state intends to reduce use of potable
water for irrigation by 50 percent, household use of potable
water by 20 percent, and overall use of electricity by 15
percent.
Many details remain to be worked out. For example, one of
several compliance options under the household water-reduction
provision calls for showerhead flow rates to be reduced from
the current 2.5 gallons per minute to 2.0 gallons per minute,
and for gravity-tank toilets to reduce water use from 1.6
gallons per flush to 1.28 gallons per flush. But because no
list of fixtures meeting those standards is available, the
draft version simply notes that “a schedule of
plumbing fixtures and fixture fittings ... shall be
provided.” Other sections, such as one dealing with
recycled and graywater irrigation systems, have yet to be
written.
However, some aspects of the new code should already be
familiar to most builders, says California Building Standards
Commission executive director David Walls. Under the current
California energy code, he notes, builders are already using a
computerized system to calculate energy consumption. The
additional reductions called for in the new code, he says, will
essentially be a matter of running the same sort of system with
different numbers.
Many mainstream builder groups have come out solidly in favor
of the new code. A California Building Industry Association
press release hailed it as “practical and
cost-effective.” Green builders, though, have been
less enthusiastic. One day before the July 18 adoption of the
draft code, building officials and a coalition of green
builders met to hammer out compromise language in several
areas. The new language makes it clear that California
municipalities are free to enact more stringent standards than
those in the state code, and that the state code is not meant
to “meet or substitute for” other green
rating systems, such as the U.S. Green Building
Council’s proprietary LEED system.
Not resolved but certain to come up again is a dispute over
the code’s standard for sustainably harvested lumber.
Most California environmental groups, including the Green
Building Council, want to restrict that designation to wood
recognized by the nonprofit Forest Stewardship Council, while
the state prefers to recognize lumber from other certifying
agencies as well.
— J.V.Offcuts
A fatal trench collapse at a Brooklyn construction site has
led to charges of manslaughter, criminally negligent homicide,
and reckless endangerment against the building’s
owner, William Lattarulo. He had hired undocumented workers to
excavate a foundation and was overseeing the work without a
general contractor. When warned that the undermined foundation
of the building next door was unstable, Lattarulo reportedly
told workers to keep digging. Thirty-year-old Lauro Ortega was
killed in the collapse; another worker was injured.
Lattarulo’s attorney told reporters that the collapse
“was an accident and accidents happen at construction
sites.”
San Francisco has announced a package of voluntary initiatives
aimed at encouraging property owners to perform seismic
retrofits on thousands of so-called
“soft-story” buildings. These structures
— which include apartments over retail or restaurant
space and homes over garages — typically feature large
ground-floor openings that make them extremely vulnerable to
twisting or buckling in a quake; dozens of deaths in the 1994
Northridge quake were attributed to soft-story failures. In
addition to expediting the review of retrofit permits and
waiving permit fees, the city will develop retrofit guidelines,
complete a study of vulnerable buildings, and create an
outreach program to educate property owners about the
importance of seismic retrofitting.
A newly identified insect that a
Texas entomologist has called “the ant of all
ants” is shorting out electrical devices in the
Houston area. According to researchers at Texas A&M
University, the so-called “crazy rasberry
ant” — named for its discoverer, local
exterminator Tom Rasberry — was first observed in 2002
but is now showing up in “remarkable numbers”
in at least seven Texas counties and is expected to spread into
other parts of the state. The insect — which
occasionally bites but does not sting — has so far
proven highly resistant to pesticides; one characteristic in
its favor is that it eats fire ants and may outcompete them in
areas where the two species overlap.
DeWalt and Paslode have each announced product recalls. DeWalt
is recalling 14,000 of its DC608 18-volt cordless brad nailers
because of a defective switch that can allow the tool to fire
even with the safety in the locked position. The gun may also
fire when the nosepiece is depressed. To receive a free repair,
call 866/220-1481 or visit www.dewalt.com. Paslode, meanwhile,
is recalling 86,000 “Tall Red” fuel cells
(part #816000) designed for use in the company’s
cordless framing nailers; the cells leak, posing a fire hazard.
For details, call 800/222-6990 or go to www.paslode.com.
