As most energy-conscious builders know, a tight house needs
a reliable source of fresh exterior air. This is particularly
true of houses with fireplaces, high-powered exhaust fans, and
other appliances that tend to depressurize the living space. A
house that doesn't have enough natural air leaks to make up for
the loss will draw the necessary makeup air from somewhere
else. That's a potentially dangerous situation because it can
lead to backdrafting and fume spillage from furnaces, water
heaters, or other atmospherically vented fuel-burning
appliances.
Several strategies can be used to admit makeup air in a more
systematic way. The simplest method -- leaving a window
partially open -- is simple and effective, but it has
significant drawbacks: It often creates chilly drafts that
cause the homeowner to cut off the air supply by closing the
window. And when the living space is under positive pressure --
when a strong wind is blowing, for example -- an open window
provides an unobstructed path that allows expensively heated
air to flow to the outdoors.
A more sophisticated approach is to install a heat-recovery
ventilator, or HRV, which recovers most of the heat in a
fan-driven stream of exhaust air by passing it through an
incoming stream of cold air in a heat-exchanger core. While
thermally efficient, HRVs have filters that must be changed
several times a year, and they typically add at least a
thousand dollars to the cost of a home.
Glenn Mitchell, a designer in Comox, B.C., has developed an
ingenious solution that represents a compromise between an
active ducted system and a simple opened window. The "poor
man's HRV," as Mitchell describes it, consists of a length of
duct leading from an intake opening in the rim joist to a
grille in the wall behind the refrigerator. When the air
pressure indoors falls significantly below that of the
outdoors, the required makeup air flows into the house through
the duct. A backdraft damper at the rim-joist end of the duct
prevents heated indoor air from passing out of the house when
the interior is under positive pressure. (Mitchell's original
installations used flexible dryer duct and a 4-inch
flapper-type dryer vent modified to work backwards, preventing
air outflow rather than inflow. A more efficient installation
would use a manufactured backdraft damper and rigid galvanized
duct with sealed seams.)
When the refrigerator is running, the waste heat from the
coils tempers the incoming air, which in turn cools the coils
and increases the efficiency of the refrigerator. When the
refrigerator is cycled off, the inlet air doesn't receive the
benefit of additional heating, but because it flows into the
narrow, out-of-the-way space between the refrigerator and the
wall, the likelihood that the homeowner will detect a cold
draft is reduced. "I've used the design on several houses and
never had a comfort complaint," Mitchell says.
