Nails as Brick Ties?
To the Editor:
In the article
"Water-Managed Wall
Systems" (3/03), the brick veneer cavity wall detail lacks
an important component to ensure proper drainage through weep
holes in the bottom course of brick. The product called Mortar
Net ensures that no mortar droppings will fall down to weep
hole level during construction, thus blocking water from
escaping through the designed weep holes at the bottom of the
cavity.
Also, galvanized or stainless-steel nails do not have the same
dimensional area that galvanized corrugated or adjustable
masonry anchors do. This detail will create a weaker veneer
system.
Charles Rozzi
via e-mail
Joe Lstiburek responds: Keeping the weep opening open is
necessary, and Mortar Net is an excellent product for this
purpose. A more traditional way to accomplish the same thing is
to leave bricks out of the assembly at the bottom to clean out
the mortar droppings. The bricks are mortared in place at the
bottom after the cavity is cleaned. Sand is placed over the
flashing or brick ledge prior to laying the bricks to act as a
bond-break to allow easy cleaning of the mortar droppings out
of the bottom of the cavity.
Some builders like to place pea-gravel at the bottom of the
opening to prevent the weep openings from being plugged. This
is a bad idea. When the mortar falls on top of the pea gravel,
we get something called "concrete."
With respect to the nails as brick ties, they are not meant to
replace engineered brick ties in commercial applications. They
are meant to replace the galvanized corrugated ties commonly
used in residential construction. These corrugated ties are
nailed in place with -- you guessed it -- nails, and the
strongest connection is the nail into the stud. The weakest
link is the tie itself. These corrugated ties are not good in
tension and they are not good in compression. During suction
wind loads, they pull out of the mortar joint like a hot knife
out of butter -- just ask FEMA about this problem. The head of
the galvanized or stainless-steel nail acts as an anchor in the
mortar bead to prevent this. Plus, the nail is great in
compression, because it's round, not flat. The geometry of the
section is more important than the dimensional area. (If you
doubt this, pick up a flat brick tie and try driving it into a
stud, like a nail, with a hammer.)
In the real world, the mortar droppings we mentioned above end
up being structural: They transfer the compressive wind load to
the wall, since the useless corrugated ties fold like a cheap
suit.
Questions Brick Ties
To the Editor:
Thanks for the great article by Joe Lstiburek ("Water-Managed
Wall Systems," 3/03). I wondered, though, why the brick veneer
wall was illustrated with nails as wall ties. Wall ties give
lateral support to a thin masonry wall but have to be flexible
enough to allow the wood frame to shrink slightly within its
masonry shell as the wood gradually dries out and the house
settles. The lower courses of masonry wouldn't be affected, but
higher in the wall the nails would begin to bend as they are
pulled down by the shrinking frame and held firm in the
brickwork by the weight of the masonry above. The wall ties
highest in the wall, while in a position of leverage to give
the most effective support to the brick wall, are also the most
affected by the total shrinkage of the frame. With relatively
little weight from the wall above to hold them secure in the
brick, rigid connections like nails could crack the masonry
horizontally near the top of the wall as the frame settles,
even slightly.
Bill Thibadeau
Norcross, Ga.
Rainscreen Siding Details
To the Editor:
I read Joseph Lstiburek's "Water-Managed Wall Systems" with
great interest. His comment that today's #15 and #30 felts do
not perform as the old-style asphalt-impregnated felts did is a
condemnation of the constant search for manufacturing things
more cheaply. Several years ago, we had a similar situation
with fiberglass roof shingles cracking all over the country
because the industry skimped on the amount of asphalt needed to
stabilize the fiberglass mats.
To prevent the problems Lstiburek describes in his article, I
have specified the rainscreen (referred to by Lstiburek as
"water-managed wall systems") on several houses, including my
own, over the last 15 years. The results appear to be very
satisfactory: no more peeling paint, rotting walls, and
splitting, curling clapboards.
I found one thing missing from Lstiburek's article: There is
no mention of the need to screen the drainage spaces to keep
out insects and rodents. For this, I have used GAF's Cobra
Fascia Vent, a spun plastic material similar to that used for
some ridge vents. It seems to be the perfect material for this
application: It is 3 inches wide by 1 inch thick. It fits well
between 1-by furring strips, compressing easily to fit the
depth of the furring. It comes in 50-foot coils, two coils per
pack. You can special-order it from building material suppliers
handling GAF ventilation and roofing materials.
I wish all builders and remodelers would get on the bandwagon
and install all sidings on furring strips as I see done on
Canadian modular units shipped to Vermont. It's an inexpensive
insurance policy that eliminates most siding callbacks and can
only lead to satisfied customers.
Henri de Marne
Waitsfield, Vt.
What To Do With Vermiculite
Insulation
To the Editor:
After reading your article "Vermiculite Insulation: Asbestos
Threat?" (In the
News, 3/03), I looked at a job renovating an attic and
noticed that the previous builder had used vermiculite
insulation. I was wondering what steps I should take to dispose
of this. Also, I was wondering if there was somewhere I could
send a sample to determine if it contains tremolite. Should
this insulation be removed, or would covering it with
fiberglass insulation be a safe alternative?
Bill Harrington
Battenkill Builders
Bennington, Vt.
Jon Vara responds: According to EPA project manager Jim
Christiansen, who is in charge of a federal cleanup of
vermiculite-containing attics in Libby, Mont., carefully
covering the vermiculite with fiberglass without disturbing it
will probably not raise enough dust to cause much of a hazard,
but it won't make the problem go away, either. If you're going
to venture into the attic, wear a well-fitted respirator
equipped with a HEPA cartridge and a disposable Tyvek suit; the
homeowner should take similar precautions before going into the
attic.
The only way to eliminate the problem is to have a qualified
asbestos-abatement contractor come in and remove the
vermiculite and confirm that the area and the living space are
free of fibers. There are well-established methods for doing
that, but it's not going to be cheap. Don't try to remove the
material yourself, or you're likely to spread asbestos fibers
throughout the living space.
To add to the confusion, there's a serious inconsistency
between law and science with regard to vermiculite. Under EPA
regulations, only substances that contain more than 1% asbestos
are regulated as asbestos-containing materials. Jim
Christiansen notes that although an individual sample of
vermiculite may contain anywhere from a nondetectable amount of
asbestos up to 5% or so, a reading at or near the bottom of
that range definitely does not mean that the material is safe.
"The 1 percent standard was developed for things like pipe
wrap, where you're talking about a solid material," he says.
"The asbestos in vermiculite is so friable and becomes airborne
so easily that it's hazardous even at very low
levels."
Safety First, Please
To the Editor:
How many times do we safety-conscious contractors need to
write in to tell you that you have a hazard on your front cover
(3/03)? Safety glasses on the saw stand, not on his face! And
tell me he is not making a cut with his left arm on the right
side of the blade.
We pay more than $30 per hundred paid on carpenters making
less than $22 per hour for workers' compensation. Do we really
want to start using your magazine as a safety test -- "What is
wrong in this picture"? I would hate to not be able to attend
JLCLive this year because of higher work comp rates. Your
careless approach to safety affects everyone from you to the
builder, costing more to the end consumer. Enough said.
I'm a Pissed-Off, Accident-Free, Safety-First General
Contractor who will continue to read your magazine even though
it's getting harder to afford paying $50,000-plus in workers'
comp per year, because of other carpenters, builders, and
publications not caring about safety.
Jeff DeBernardi
DeBernardi Development
Pleasanton, Calif.
Bathroom Design by Magic
To the Editor:
In the article "When a Double Vanity Just Won't Fit"
(Kitchen &
Bath, 3/03), you solve a vanity problem in the way we all
wish we could, by bending the laws of physics. Look closely at
the two vanity drawings and you'll see that the scale magically
changes from one to the next, despite the sink bowls remaining
the same. In the top figure, even the measurements of 30 and 15
inches add up to being shorter than the 36 inches marked in the
lower figure.
Dan Travers
Seattle, Wash.
Post Haste
To the Editor:
Regarding "Fitting Post to Stone, Teriyaki Style"
(Backfill,
3/03), were I the building inspector or owner's representative,
I'd reject this work. There is no provision to adequately
resist vertical lift due to frost heave in the soil. The
grouted rod can't begin to match the forces of frost-heaving
soil.
Robert J. Randall
Randall Engineering
Mohegan Lake, N.Y.
Thanks for the comment. Given the soil type -- sand -- and
all that gravel placed around the sonotube-BigFoot combination,
frost heave seems unlikely, in our opinion.
-- The Editors
Swelling of OSB Roof Panels
To the Editor:
The writer who has trouble with OSB swelling
(Q&A, 4/03)
failed to mention whether he spaces the OSB as per manufacturer
recommendations. It has been our experience that when the
recommended 1/8-inch space is left at all panel edges, the OSB
has room to expand and contract, which seems to eliminate, or
at least minimize, the edge swelling that the article
describes. Unfortunately, information from APA indicates that
this is only a recommendation, not a requirement, meaning that
the contractor makes the decision whether to go "the extra 1/8
inch."
Van Thornton
Niles Township Building Department
Niles, Mich.
