A.Gary Katz responds: I
feel your pain. Finish carpentry, especially door hanging, is a
tool-heavy trade. Here's the best advice I can give to any
part-time door hanger.
First, put together a good door bench or a door stand. You can
cobble a stand together from some scraps of 2-by and 1-by
(Photo A), or you can make a full-blown bench. I'd suggest
making the bench. A good door bench has a lot of uses. The legs
fold up, so the bench is easy to store and transport, and once
you start hanging doors, you'll never stop — there's good
money in it. (See
"Hanging a New Door
in an Old Jamb," 8/99, for more on building a door
bench.)
But it's the tools that cost real money. I'm figuring you
already own a good-sized drill, a cordless driver, and a
circular saw, so a plane might be your most expensive purchase.
As a full-time door hanger, I prefer a Porter-Cable 126, which
is sold in a kit, #9118, for about $400 (Photo B). For just a
few doors, you can also use a regular plane, like the Bosch
1594K, one of the few multi-use planes equipped with an
adjustable bevel guide ($155 on the web).
You might be able to avoid buying a plane altogether if you can
purchase prebeveled doors. We use them all the time.
You'll also need a router. For door hanging, I prefer
Porter-Cable's 7/8-hp model #100, which, unfortunately, may
have been discontinued (Photo C). For a multipurpose router,
I'd suggest a Bosch 1617evs ($170 on the web), which has a
micro-adjustment knob as well as a quick-change template guide
system. You'll need that template guide because you'll have to
use templates for mortising hinges and locks.
I buy all hinge templates and most lock templates from Templaco
(www.templaco.com)
because they cost less to buy than to make, and Templaco's
templates are always dead-on accurate. For those 1 3/8-inch
doors on your job, you'll only need a single-pocket template
(Photo D) for 3 1/2-inch hinges ($20). If you're hanging new
doors in new jambs, you can get a full-length template that
lays out all three hinges.
For boring doors, you could buy a good-quality hole saw for the
cylinder and a spade bit for the edge bore, and live
dangerously! But if you can, when it comes to boring doors,
break the bank and go all the way. Templaco sells a couple of
great kits (BJ-115 or BJ120, about $370) that include all the
latch and strike templates you'll ever need, plus the boring
jig (Photo E) and bits. If you bore more than a dozen doors a
year, think about upgrading to their carbide spur 2 1/8-inch
bit ($127). You'll never regret it. (See
"Installing a
Cylindrical Latchset," 12/00.)
These are only the basics. When you're ready for flush bolts,
mortise locks, and auto-bottoms, contact me at JLC Online's
Finish Carpentry Forum
and I'll tell you more.
Gary Katz
is a frequent contributor to
JLC,
author of Finish
Carpentry, and moderator of JLC
Online's Finish Carpentry
Forum.
