Download PDF version (693.7k) Log In or Register to view the full article as a PDF document.
When my wife and I bought our 1850s farmhouse, it had none of the typical details I would expect to see on a home of the Greek Revival period — wide corner boards, built-out rakes, a heavy frieze, boxed cornice returns. So I set out to learn how to re-create those trim elements, using my place as a test case.
I started by studying my neighbors’ houses, then hit the bookstores and libraries. Although 18th- and 19th-century American builders borrowed many details from Greek and Roman architecture, construction references from the period are hard to come by. Probably the most helpful are the books by Asher Benjamin, who in the early 1800s wrote and illustrated several texts specifically for carpenters. His carefully drawn plates surely inspired many New England buildings, and they helped me better understand classical proportions and details.
Since practicing on my own house, my company has completed a number of projects in the Greek Revival style, both new construction and renovations (see photos, above). This article focuses on how we lay out and build the tricky cornice returns, using PVC trim instead of pine (see Figure 1).
Figure 1. On an authentic Greek Revival cornice, the crown molding along the eaves turns up the rake, which slightly elongates the rake profile. Also, the fillet — the narrow strip at the base of the crown — splits in two, running up the rake and along the top of the cornice return. To avoid having to fabricate two crown profiles — not to mention some tricky carpentry — most builders of traditionally styled homes substitute the simpler “poor man’s cornice.”
Simpler Details
Our most recent project was an overhaul of the Captain Loring House, circa 1850. Although the house’s original crown molding had the traditional ogee profile (Figure 2), much of it was in rough shape and some sections had been replaced with newer moldings that didn’t quite match. This was especially noticeable at outside corners, where various handymen had tried to cover up botched miter cuts with lead flashing and caulk.
Figure 2. Considering its age, this mid-19th-century Greek Revival cornice (left) has held up well. Note the split fillet where the rake crown molding resolves into the profiled wood gutter along the eaves. At right, the author’s modern interpretation.
The problem is that where a rake molding returns along a plumb-cut eaves fascia, as on a true Greek Revival, the molding gets narrower and the profile changes. Had we chosen to replicate the original ogee molding, we would have needed to order custom shaper knives to create the matching profiles. And because the house had several roof pitches, we would have needed a different set of cutters for every pitch.
I knew that this approach was too expensive; instead of a profiled crown, we would use flat stock with a 55-degree spring angle, as I had on previous jobs. The big advantage of a flat crown — besides the fact that it can be made from standard square-edged stock — is that there’s no profile to match at the corners.
Scale Drawings
I began by drawing scale section views through the rake and eaves, taking the building’s existing 8-inch soffit as the starting dimension (Figure 3). The drawings gave me the sizes of the various pieces of PVC stock we would need, and helped us visualize how we would create the fillet — the square-edged piece at the base of the rake crown, which splits at the corner and runs horizontally along the eaves and back the other direction along the top of the cornice return. This is a key element of the true Greek Revival style — a detail we’d have to get right to mimic the original.
Figure 3. Starting with the known dimensions shown here, the author used scale section drawings to figure out framing and trim dimensions along the eaves and up the rake. Note the 3/4-inch fillet at the base of the crown — a key element of the Greek Revival style.
Full-Scale Mockup
Even with the section drawings, it was difficult to visualize the corner where the rake meets the eaves. I’m no math wizard, so I decided that we would work out the compound miters and other unknowns before going up on the roof (Figure 4).
Figure 4. Using a mockup of a 12-over-12 roof (top left), carpenter Dave Crosbie first tacks pieces of the rake profile to the frame, letting the flat crown run long. Then, using scraps of trim, he determines the point against the fascia where the eaves crown intersects the rake crown (top right). Accounting for trim thickness, he sets jet blocks for the soffit (middle left), then carries this elevation around the corner to set the return at the same height (middle right). After capping the return and adding fascia and rake trim (bottom left), he finds the crown miter angles by trial and error and visually determines the width of the narrower eaves crown (bottom right).
Using a mockup of a 12-pitch roof corner, lead carpenter Dave Crosbie first tacked pieces of the rake trim in place along the fly rafter, letting them run long at the bottom. Then, by butting pieces of the eaves trim against the rake trim, he was able to determine the exact point against the fascia where the mitered eaves crown meets the mitered rake crown.
Working down from that point, he established the elevation of the soffit, based on the dimensions on the drawing. He then attached jet blocks to the bottom of the rafter tails and projected this elevation back around the corner to establish the placement of the cornice return framing. Finally, he was able to easily establish the exact width of the narrower eaves crown and to determine the exact compound miter angles that would be required.
These compound cuts were anything but obvious, and changed with every roof pitch. Using mockups and trial and error, we eyeballed our way to some surprising angles. For a 12-pitch roof, for example, the eaves crown called for a 35-degree angle with a 48-degree bevel, while the rake crown board required a 10-degree reverse angle (meaning the long point of the cut is at the bottom of the crown) and a 48-degree bevel.
Top-Down Installation
The first step in fitting the trim was framing the gable overhangs. We ripped the ladder stock from 2x8s, assembled the ladders on the ground, and installed them with TimberLok screws (Figure 5). For the PVC trim, we followed the same installation sequence we had used for the mockups, starting at the gable peak and working down to the eaves.
Figure 5. Overhang ladders ripped from 2x8s attach to the gable with TimberLok screws (top). Since it’s mitered at both ends, the carpenters work the PVC trim from the ridge down in sections (middle). Seams are glued with Bond&Fill (bottom).
We glued the joints with Bond&Fill SlowCure (877/822-4615; bondfill.com), a sandable waterproof adhesive made for use with PVC trim.
At the eaves, we temporarily tacked the fascia and crown in place, letting them run long so we could establish the eaves soffit line. We then framed the eaves soffits, using jet blocks, just as we had done with the mockup.
Bird Box
Once the soffit elevation was established, we could frame the cornice return (Figure 6), a distinctive feature of this trim style that seems to go by many names; Dave calls it the “bird box.” The length of the box is somewhat arbitrary — whatever looks “right” relative to the rake and frieze above and the corner board below it. The frieze elements under the eaves wrap around the top of the corner board and return to the wall below the cornice, suggesting a column capital.
Figure 6. Shims at the back provide a slight slope to the cornice return’s cap (left). After the return is finished, the bottom section of the rake soffit can be installed (right).
Once the eaves framing and bird box were in place, we installed the PVC soffit boards on the eaves and the box, followed by the face trim and cornice top. We ripped the top of the cornice from a piece of 1x12, installing it with just enough slope to allow for runoff (Figure 7).
Figure 7. The eaves frieze wraps the corner and works in conjunction with the cornice to create the illusion of a capital over the corner board “column” (left). Lead flashing caps the cornice, and the rake frieze dies on top (right).
We then installed the bottom section of the rake soffit board, which we fitted to the sloped angle of the cornice top, sealing the joint with Bond&Fill. The rake frieze lands on top of the cornice, over a piece of lead flashing.
The flat crown extends the edge of the roof considerably forward of the rafter tails, so we added triangular nailing blocks behind it and brought the roof sheathing to its back edge. The roofing was an architectural-grade asphalt shingle, but instead of applying a metal drip edge, we used pressure-treated red cedar shingles so as not to detract from the crown.
Trevor Kurz is president of Kurzhaus Designs in Orleans, Mass.
