Cutting to Length
After I’ve measured all the doors, I return to the
chop saw to cut the casings to length. The measurements on the
story pole represent the short point of the miter (less the
1/4-inch reveal). Before I can make any cuts, I need to find
the long point — in other words, I need to add the width
of the head casing plus the 1/4-inch reveal. I also do this
without measuring, using the story pole and a couple of
spacers. First, I lay the story pole on the left extension
table so that the right end falls about 3 inches short of the
saw blade. Against the far end of the pole, I place a scrap of
casing laid flat, then a 1/4-inch spacer (Figure 4).
Figure
4. Before cutting the trim to length, the short-point
markings are converted to long-point cut lines by placing a
scrap of casing and a 1/4-inch spacer between the far end of
the story pole and a layout stop clamped to the extension table
(top left). At the other end of the pole, a separate Quick Rule
(top right) is aligned with the one on the story pole and glued
to the saw fence (bottom).
Next, I bump a stop against the spacers and clamp it to the
surface of the extension table using a Vise-Grip welder’s
clamp (American Tool Co., 701 Woodlands Pkwy., Vernon Hills, IL
60061; 800/866-5740). For the stop I use a scrap of hardwood
cut perfectly square, with a piece of peel-and-stick sandpaper
applied to the bottom to keep it from wiggling while it’s
being clamped.
Leaving the spacers temporarily in place, I return to the
blade end of the story pole and stick a Quick Rule on the chop
saw fence so that it lines up with the one on the story pole. I
can now remove the spacers and start marking and cutting
casings.
Returning to my example of door #1H: To cut the left casing
(lH + 3), I’d place one of the left-mitered casings on
the extension table with the mitered end against the stop, mark
the casing three hash marks longer than the centerline of the
Quick Rule on the fence, slide the casing over to the saw
blade, and hack it off square. For the right side of door #1H,
I’d mark a right casing 11/2 hash marks short of the
centerline on the Quick Rule. If I’d made a notation to
scribe the cut to fit the floor, this is when I’d make
that adjustment. To avoid that queasy feeling that hits when
you discover you’ve just cut a whole house worth of trim
too short, I always stop and dry fit the first two pieces
before going further.
