A.Jennifer Hause
responds: For the most part, there are few
problems with septic systems associated with the
use of low-flow fixtures. While it’s true
the wastewater is more concentrated, the increase
in pollutants will likely be insignificant in
existing septic systems that were sized for older
fixtures ( problems only arise when you get a flow
reduction of 20% or more for a given amount of
effluent).
More often, the use of low-flow fixtures is a
benefit to a septic system because it helps reduce
the size of the drain field and reduces "hydraulic
overloading" of septic tanks. Excessive amounts of
water in the system, typically from laundry, toilet
flushing, and bathwater, commonly cause undersized
septic tanks to overflow, sending solids and
pollutants on to the disposal field. Using low-flow
fixtures can offset these heavy amounts of
wastewater, so the system operates properly. Under
optimal conditions, you want wastewater to stay in
a septic tank one to two days. This allows the
solids to settle, the scum (including fats and
greases) to rise, and pollutants to gradually
decompose, allowing a partially clarified effluent
to flow on to the drain field.
Any new septic system should be properly sized
to handle whatever wastewater loading is expected.
At the very least, most states require a minimum
septic tank size (ranging from 500 to 1,000
gallons). Some states may require the septic tank
to be sized to hold a certain number of gallons per
bedrooms (often about 250 gallons per bedroom).
Similarly, the drain field must be sized according
to on-site soil conditions (based on the results of
a percolation test) and the expected waste
flow.
Jennifer Hause is a wastewater engineer with
the National Small Flows Clearinghouse at the
Environmental Services Division of West Virginia
University (800/624-8301). Callers may ask to speak
with any of the wastewater engineers available, 8
a.m. to 5 p.m. EST.
