New Products From Kleer, Azek, Cord-Pro, GE, and More
0908d_rm_PRODFL_DesignerDoors.jpg(300)Designer Doors. A new line of overhead doors makes custom looks more affordable. Woodscapes by Designer Doors is offered as a mid-range product line with doors available in clear-grade Western red cedar or African mahogany over a rugged kiln-dried pine frame. More than 70 designs are available. Customers can choose from four muntin styles, and vertical or spined herringbone orientation. Moisture-control features include vent holes that allow air movements, and beveled edges to deflect water. 800.241.0525. www.designerdoors.com.
0908d_RM_PRODFL_SJ2.jpg(300)SJ2 Industries. Don’t compromise a circular saw’s safety features by shimming or pinning the guard. Instead, try the Original 3rd Hand Circular Saw Saf-T Guard Lift. Designed for worm-drive circular saws, the thumb-actuated guard lets users raise and lower the guard with the same hand that operates the saw. The setup allows the guard to return to its fully closed position immediately upon release. 805.445.1066. www.the3rdhand.com.
0908d_rm_PRODFL_Azek(300)Azek. On the heels of its Azek Deck product launch, the maker moves to home entryways with Azek Porch, offering the same performance characteristics. Azek Porch plans provide a low-maintenance surface that resists stains, moisture, mold, and mildew, scuffs, scratches, and fading. Available in brownstone or slate gray color, the tongue-and-groove 1×4 planks install with traditional woodworking tools and are up to 40% lighter than wood composites. 877.275.2935. www.azek.com.
0908d_rm_PRODFL_RevAShelf.jpg(300)Rev-A-Shelf. Conceal and access laundry in one easy motion with the TOHB Tilt-Out Hamper. Simply mount the basket rest to the door of a bottom-hinged cabinet for slide-in, slide-out basket removal. The series is available in 16- and 21-inch widths, and in chrome, satin nickel, or oil-rubbed bronze. The kit contains the hamper, basket rest, and screws. 800.626.1126. www.rev-a-shelf.com.
0908d_RM_PRODFL_ORG.jpg(300)Org.Org home organization products lend structure to any wardrobe. Users can maximize wall space with corner shelves and customize the design with drawers, shelves, baskets, and more. Org products come in a choice of nine laminate finishes and eight wood finishes. Custom organization solutions are also available. 800.562.4257. www.homeorg.com.
0908d_RM_PRODFL_GE.jpg(300)GE. Instead of trying to wrangle an unwieldy caulk gun for a small job, try new GE Caulk Singles. The single-use disposable packages each contain 1.25 ounces of caulk and dispense easily with one hand. The simple-looking but highly engineered package incorporates a geometric bellows and other hidden mechanisms to evenly dispense caulk while reducing waste. One package is ideal for small jobs, such as sinks, fixtures, and touch-ups, while two packages will be enough for most bathtub or window jobs. Use three packages for large jobs. The caulk is available in white paintable acrylic, or white or clear waterproof silicone. 877.943.7325. www.gecaulksingles.com.
0908d_RM_PRODFL_Kleer.jpg(300)Kleer Lumber. An expanded line of extruded cellular PVC moldings for interior and exterior applications now includes 16 styles and thicknesses. Available pieces include base cap, bed, brick, cove, crown, drip cap, J-channel, quarter round, rake, shingle band, and sill nosing. Sizing varies and custom sizes can be special-ordered. The material is designed to look, feel, and work like wood while resisting rot, warping, splitting, and insect infestations. 866.553.3770. www.kleerlumber.com.
0908d_RM_PRODFL_Cordpro.jpg(300)Cordpro. Use the Cordpro to make electrical cords, hoses, and cables more manageable. With the Cordpro placed at the center of a length of cord, users can wrap each half of the cord separately around two independent compartments. The result is a cord that unwinds easily from either end while the remaining cord is neatly contained. Three sizes are available for wrangling everything from power tool cords to computer cables. 800.700.6784. www.cordpro.com.
Lauren Hunter
