Spec Book: Rangehoods & Ventilation
Take care of “the air up there” with these ventilation units that remove pollutants from indoor air.
RangeCraft. Decorative range-hoods from the Miami collection can be made from copper, brass, stainless steel, or any combination of these, with mirrored or antique finishes. All of the maker’s hoods come standard with patented Micro Baffle Filters and halogen lights. Choose from super-quiet 600 cfm or 1,200 cfm internal fans, or a remote fan. 877.724.6637. www.rangecraft.com.
Panasonic. Improve energy efficiency and homeowner health with the WhisperComfort fan, a new spot energy recovery ventilator (ERV) and the first ceiling-insert ERV available in the U.S. Using two ducts, the fan exhausts stale air and brings in fresh air from outside. Its low-rate continuous run helps ensure that VOCs and other indoor air pollutants are vented out and replaced with fresh air. The fan’s capillary core adds heat and moisture to the incoming air to temper it and maintain a comfortable indoor living environment. 800.211.7262. www.panasonic.com/ventfans.
American Aldes Ventilation.VentZone systems offer dynamic zone control of ventilation airflow. The Energy Star-compliant systems are designed to eliminate unnecessary ventilation and increase airflow to areas where it’s most needed. Systems combine terminals that control low-energy fans to ventilate only desired areas. Designed for 4- or 6-inch ducts, the fans have a low profile, allowing them to be installed between floors. 941.351.3441. www.americanaldes.com.
Broan. The UP27 professional-style rangehood is the newest addition to the Best by Broan product line. Ideal for retrofit applications, the UP27 offers contemporary style and the high performance of larger professional-style hoods in a compact, undercabinet profile. A seamless welded design uses brushed stainless steel that offers durability and clean, sleek lines. In addition to internal and external blower options, the hood features Evolution baffle filters for improved filtration. 800.558.1711. www.bestbybroan.com.
Zephyr. A stylish new design from Fu-Tung Cheng, the Cache rangehood offers a streamlined design for an elegantly ordered kitchen. Behind the hood’s front panel is a storage compartment ideal for keeping herbs, spices, and kitchen tools. The handle also doubles as a utensil rail. The stainless steel unit is available in 30-, 36-, and 48-inch widths. 888.880.8368. www.zephyronline.com.
Lauren Hunter
