Q Are ledger lag-bolting schedules that were developed for 2-by rim joists adequate for engineered rims? It seems that lag bolts would be more likely to pull out of a thinner engineered rim than out of a thicker 2-by Doug fir rim joist. A Christopher DeBlois, a structural engineer with Palmer Engineering in Tucker, Ga., responds: You’re right. Lag bolts don’t get the same purchase in a 11/4-inch-thick engineered LSL (laminated strand lumber) rim joist as they do in 11/2-inch-thick framing lumber. If a lag bolt is properly installed, with its tip well through the rim joist and only
How New Decking Technologies Reduce Risk
Brought to you by Deckorators4 MIN READ
First Impressions: TrueFrame Joist
Brought to you by UFP ProWood4 MIN READ
Designing Outdoor Kitchens
7 MIN READ
