Exterior Soundproofing That Works
Airtight components, acoustical sealants, and sound-absorbing surfaces provide a quieter living space
17 MIN READ
Exterior Soundproofing That Works – Continued
Adding Mass
Normal wood-frame construction — 1/2-inch drywall, 3 1/2-inch studs and insulated cavity, and 5/8-inch sheathing with siding — does not create a noise path that requires treatment. However, uninsulated wall and ceiling framing may require treatment. A ceiling that is part of the roof assembly is exposed to more outside noise energy than a flat ceiling under an attic space. To absorb some of this energy, we increase the surface mass by applying an additional layer of 5/8-inch blue-board with a plaster skim coat, going directly over the existing layer of gypsum (Figure 7). Where attics exist above ceilings, no acoustical treatments are generally required as long as the ceiling has at least one layer of 1/2-inch gypsum board, and there is at least 9 inches of insulation in the joist bays.
Figure 7. Applying the principle that surface mass absorbs noise energy, adding an extra 5/8-inch-thick layer of gypsum blueboard with a plaster skim coat helps to reduce the noise transmitted through flat-roof and cathedral-style ceilings.
Quiet room. Boston’s Logan Airport program offers participating homeowners an extra measure of sound insulation beyond the typical door and window treatments. Homeowners may choose one room in their home to receive a “quiet room” treatment that effectively creates a room within the existing room. Any wall or ceiling in the designated room that has exterior noise exposure will have a second wall or ceiling constructed 1 inch inside of the existing surfaces (Figure 8). This, of course, results in some downsizing of the room’s dimensions.
Figure 8. Double wall and ceiling construction decouples, or isolates, the interior space from the exterior building envelope. Although the existing room size is slightly reduced, the thunder of a passing jet is lowered to background noise.
Surface isolation. Decoupling these rooms works very well — the thunder of a jet departing is reduced to background noise. The average tested noise rating of a quiet room is 45 dB — a 10 dB, or 50%, noise reduction beyond that achieved by our normal door and window treatments.
For these rooms to be optimally efficient, careful attention to detail is a must. We make sure that no elements bridge the gap between the new and existing walls and/or ceilings, and that seams and holes are tightly sealed. These are the steps:
• Set the new wall plate in acoustical sealant where it is in contact with the floor.
• Seal all electrical wall switches and receptacles with the same sealant.
• Use the standard elements of a normal 2×4 wood-framed wall in the double-wall construction, and include R-11 insulation (Figure 9).
Figure 9. Double-wall 2×4 framing set in acoustical sealant caps the top and bottom of an existing boxed-out lower wall section. Fiberglass batt insulation absorbs sound energy. Resilient channel crosses 1×3 strapping over the existing ceiling, which is covered with semi-rigid acoustical fiberglass insulation, followed by a layer of 5/8-inch-thick blueboard with a plaster skim coat.
• Replace any windows in the existing wall with a new acoustical window.
• The double wall also receives an acoustical window, creating a double window construction (Figure 10).
Figure 10. Even the windows get doubled in a sound-insulated room. Thermopane glass, minimum 2-inch air spaces between units, and a high-performance storm window present an effective barrier to external noise.
• To decouple the ceiling, install 3/4-inch-thick acoustical fiberglass insulation between wood strapping, directly over the existing ceiling.
• To reduce the transmission of vibration, cross the wood strapping with RC-1 resilient channel, and fasten a layer of 5/8-inch blueboard to it.
• A layer of skim-coat plaster and a prime coat of paint finish the job.
The only thing left for the homeowner to do is the final painting and decorating.
One of the main goals of the residential insulation programs is homeowner satisfaction and community goodwill toward the airports. As a testament to the adaptability of people, not to mention their savvy in not passing up a good deal, one program participant, when asked if she noticed the difference after her home was sound-insulated, responded, “I’ve lived here for 32 years, so I don’t even think about the noise anymore, but I’m happy with the job —it looks very nice.”
Michael Payne, AIA, is a principal and architect at the Jones Payne Group in Boston, Mass.
Sources of Supply
ChemRex
889 Valley Park Dr. Shakopee, MN 55379 800/433-9517 http://www.chemrex.comSonneborn’s Sonoclastic NP1 Sonneborn’s Sonolastic Omniseal
Graham Architectural Products
1551 Mount Rose Ave. York, PA 17403 800/755-6274 http://www.grahamarch.comAluminum acoustical windows
Harvey Industries
1400 Main St. Waltham, MA 02451 800/942-7839 http://www.harveyind.comVinyl acoustical windows Storm doors
Hess Manufacturing
P.O. Box 127 Quincy, PA 17247 800/541-6666 http://www.armaclad.comArmaclad storm doors
J.B. Sash and Door Company
280 Second St. Chelsea, MA 02150 800/648-9339 http://www.jbsash.comWood replacement windows Primary solid-core wood doors
Kolbe & Kolbe
1323 S. 11th Ave. Wausau, WI 54401 800/477-8656 http://www.kolbe-kolbe.comWood replacement windows
M-D Building Products/ Maclanburg-Duncan 4041 N. Santa Fe Oklahoma City, OK 73118 800/654-0008 http://www.mdteam.comFlex-O-Matic door sweepMarvin Windows
P.O. Box 100 Warroad, MN 56768 888/537-8266 http://www.marvin.comWood replacement windows
Mohawk Flush Doors
P.O. Box 112 Northumberland, PA 17857 714/473-3557 http://www.mohawkdoors.comPrimary solid-core wood doors
Mon-Ray
801 Boon Ave. North Minneapolis, MN 55427 800/544-3646 http://www.monray.comAluminum acoustical windows Patio storm doors
Morgan Manufacturing
228 W. 6th Ave. Oshkosh, WI 54902 920/235-7170 http://www.doors-windows.comPrimary solid-core wood doors
Pecora
165 Wambold Rd. Harleysville, PA 19438 800/523-6688 http://www.pecora.comDynatrol I, 864, and 863 sealant
Peerless Products
P.O. Box 2469 Shawnee Mission, KS 66201 800/279-9999 http://www.peerlessproducts.comAluminum acoustical windows Sliding storm doors
Premier Sealants
P.O. Box 484 Elmer, NJ 08318 856/256-1111 http://www.premiersealants.comTremco’s Dymonic sealantRepublic Windows 930 W. Evergreen Ave. Chicago, IL 60622 800/248-1775 http://www.republicwdws.comVinyl acoustical windows
Visco Weather Seal Products
166 Valley St., Bldg. 7 Providence, RI 02909 401/831-1665 Uni-Check door sweep
Weather Shield Mfg.
One Weather Shield Plaza Medford, WI 54451 800/222-2995 http://www.weathershield.comWood replacement windows
