Painting Lessons
Case studies teach how to steer clear of exterior paint failures.
JLC ??JUNE 1991 Case studies teach how to steer clear of exterior paint failures Fading Fast Painting contractor Mark Robson, whose Ram-Mar Painting is based in Santa Barbara, Calif., recently painted a high-end multiunit condo project in Newport Beach. The problem. The building interiors were spec’d out in straight white, both walls and trim. The plan called for a good oil enamel on the baseboards and a lot of other interior trim that normally doesn’t get a gloss finish. The walls were flat latex. And within six months, the trim in some of those houses was almost a mustard color next to the white walls. The enamel had yellowed, but the flat latex remained white. “The builder wanted to know if we were using
