Case Study: Framing an Engineered Floor
"Parallel-strand lumber, floor trusses, and steel I-beams solved the problem of long spans and cantilevered loads in this second-story addition"
As a design-builder specializing in custom waterfront homes and challenging renovations, I encounter a lot of unusual structural problems. When my design involves long spans or heavy loads that exceed the capacity of ordinary sawn lumber, I turn to manufactured products like steel beams, engineered timbers, wood I-joists, and floor trusses. Steel, trusses, and engineered wood products expand my range of design options. But because I also build all my own designs, getting the job done on schedule and making a profit are important concerns. Although steel is light, strong, and economical, as a builder I often prefer to use engineered lumber because it speeds up and simplifies the framing. Whenever we’re
Andrew DiGiammo
Architect and builder Andrew P. DiGiammo owns and operates Residential and Commercial Master Builders of New England, based in Assonet, Mass.
