Practical Engineering: Buckling Under Pressure
Most framers install thousands of wooden studs and built-up posts every year without ever questioning their ability to carry vertical loads. Conventional job-site wisdom says that, in most cases, 2x4s are plenty strong and that 2x6s, used primarily for the extra room they give for insulation, are overkill — even on 24-inch centers. For the most part, this conventional wisdom is right. Studs and columns rarely fail from compression — that is, being crushed under load. But there are situations where extra wall height or greater than normal loading might cause a stud or a built-up post to fail by buckling, or suddenly bowing out to one side. In theory, a slender column made from elastic material such as wood
John Siegenthaler, P.E.
John Siegenthaler, P.E., operates Appropriate Designs, a building systems engineering firm in Holland Patent, N.Y. He is the author of the course materials for the ASSE 19210, Hydronics Heating and Cooling Installer Professional Qualification Standard, as well as the author of "Modern Hydronic Heating for Residential and Light Commercial Buildings," and “Heating With Renewable Energy” (both published by Cengage).
