Prefab Shear Walls
New engineered components promise cost savings and guarantee compliance with strict seismic codes
PREFAB SHEAR WALLS In my 30 years of framing houses on the West Coast, I’ve seen a steady rise in the use of techniques and materials designed to resist the powerful lateral forces imposed by earthquakes — “shear” forces, as most West Coast carpenters call them. When I first started framing in Southern California, we simply used let-in 1×6 braces and 1/2-inch-diameter foundation anchor bolts 4 feet on-center. By the end of the ’70s, let-in bracing began to give way to small amounts of shear-nailed plywood. By the mid-1980s, exterior shear-ply completely covered exterior frames, and, for good measure, a few hold-down brackets were tossed into the mix. But none of this compares to the
Don Dunkley
Don Dunkley is a semi-retired framing contractor from Cool, Calif., and the former show manager for JLC Live. More than any other person, Don is responsible for working out how to put "live" in the JLC Live expo.
