Radiant Slab on a Tight Budget
Using a custom concrete mix kept costs down on this in-floor hydronic heating system
As a heating design engineer, I spec a lot of hydronic radiant-floor heating systems for both residential and commercial jobs. I would probably spec more residential systems, however, if they weren’t so expensive. Though initially interested, many homeowners are eventually scared off by the high costs. One of the reasons for the high cost has to do with the cost of the thin slab itself. The usual method of installing the thin slab for hydronic floor heating uses a self-leveling gypsum-based underlayment, such as Gyp-Crete. The underlayment is typically poured near the end of the job, after all the walls are up and the house has been closed in. These systems must be installed by a certified
John Siegenthaler, P.E.
John Siegenthaler, P.E., operates Appropriate Designs, a building systems engineering firm in Holland Patent, N.Y. He is the author of the course materials for the ASSE 19210, Hydronics Heating and Cooling Installer Professional Qualification Standard, as well as the author of "Modern Hydronic Heating for Residential and Light Commercial Buildings," and “Heating With Renewable Energy” (both published by Cengage).
