A Finish Carpenter’s Wish List
"If you want the finish work to look its best, the framers have to do their share"
Precision Counts I start my list with a plea for precision and emphasize the outcome of lazy framing. ?Make the walls plumb, especially in the areas around doors and outside corners. If a wall isn’t plumb at a door opening, there isn’t always enough slack in the finish work to be able to hang the door plumb without mucking up the trim. And if a wall is out of plumb at the corner, it will be tricky to trim out without the moldings reflecting the bad angle. ?Set partition walls straight, especially in runs containing door openings. Most framers snap a nice straight chalk line for a partition wall, but they don’t always fasten the bottom plate to it. Unfortunately, the
