Clever Storage for Kitchen and Bath
For the best storage solutions, you need to think outside the box
6 MIN READ
Clever Storage for Kitchen and Bath. continued
Keeping the Counters Clear
Problem: Your client uses every small kitchen appliance ever heard of but wants the countertops to be kept clear.
Solution: We like to design workspaces behind closed doors. A full-height pantry cabinet can be equipped inside with countertop, electrical outlets, and pullout breadboards for additional horizontal workspace. Most countertop kitchen appliances are designed to fit under upper cabinets placed 18 inches off the countertop, so be sure to allow at least that much space inside the pantry. Also, be sure to provide adequate clearance for heat-generating appliances such as toaster ovens.
Dogfood Drawer
Problem: Brutus, the 150-pound indoor dog, eats in the kitchen, and his food and supplies take up more space than those of your clients.
Solution: Create a special drawer for his food and scoop, as well as the leash, brush, and other supplies. This deep drawer can hold one large bag of kibble and should be placed close to the feeding station. If you want, you can put the food and water dishes in an adjacent pullout or toe-kick drawer: Pull it out at mealtime, and push it back when he’s done. The kitchen will be less cluttered with no big bag or messy dishes to trip over.
Storing Everyday Dishware
Problem: Your clients’ collection of fancy dishware is displayed on open shelves or in glass-front cabinets, so where do they store the everyday stuff?
Solution: Use a full-height pantry for storing dishes, not just food. Pullout shelves on full-extension slides make it easy to access dishes that are stored in back. These pantry cabinets are usually much deeper than a typical upper cabinet, and this allows for storage of big platters, chargers, and mixing bowls, as well as everyday dishes and glasses.
Just Like the Restaurant Kitchen
Problem: Your client is a professional chef and wants her home kitchen to be as functional as the restaurant kitchen.
Solution: Her restaurant kitchen is functional because everything is within reach, not behind doors or in drawers. Create open upper cabinets to stack cookware and serving plates. This approach can be decorative as well as functional if the dishware is attractive. An island can have open shelves for large pots and trays and can allow easy access to bins of vegetables stored there. The cook shouldn’t have to turn around or walk to another area of the kitchen when all six burners of the professional range are in use, so hang utensils near the range for easy reach at crucial times.
Recycling Made Easier
Problem: Where do you put the recycling bins that are so common these days? After all, recycled items are often wet or dirty, so no one wants to haul them across the room.
Solution: The 24×36-inch space under the sink provides the solution. This pullout puts two bins in the work area, right where the client needs them. The standard 10×14 trash cans rest on a pullout attached to the back of a drawer front that looks like a pair of doors. The cans are mounted sideways to clear the plumbing, and there’s room left over to store shorter items in back.
Making the Most of the Lav Cab
Problem: The client wants drawer and shelf storage in a vanity, but the sink bowl and plumbing are in the way.
Solution: One of our cabinet subs suggested this bathroom vanity, which has a 5-inch-deep drawer on the bottom behind the cabinet door. On top of the drawer is a shelf for storing taller items, making them easier to reach than if they were on the floor of the cabinet. The drawer keeps smaller items organized and off the countertop, and it can be made deep enough to store extra toilet paper. There could just as easily be more than one drawer, or the drawer could be accessible without opening the door.
Blind Corner Engineering
Problem: What do you do with blind inside corners in the base cabinets?
Solution: Everyone knows about the lazy susan, but some of our clients prefer Häfele’s dual-function slide-out (800/667-8721, www.hafeleonline.com/usa). This trick gizmo especially appeals to our engineer clientele. One wire storage unit is attached to the door, so that when the cabinet door opens, it comes out into the room, pulling another wire storage unit out of the dead space and into the cavity left by the unit attached to the door. The door unit can then open another 180 degrees to make access to the inside unit easier. I don’t recommend these blind corner units for heavy things like canned food, but they’re suitable for lighter items.
Susan Davisis co-owner with her husband, Bob, of Spectrum Fine Homes, Inc., in Mountain View, Calif.
