Fitting Baseboard Around an Electrical Outlet
Electrical outlets in older homes are sometimes located along the baseboards rather than higher up on the wall. During a renovation project in a home like this, where the top edge of an existing outlet is taller than the height of the baseboard, it is necessary to either relocate the outlet or notch the baseboard around the outlet – tricky when the baseboard trim has an elaborate profile. In this Instagram post, Marlon Rodriguez (carpentry_bymar) demonstrates a fast and accurate method for notching a profiled baseboard around an electrical outlet. The key to his method is the simple notching jig he uses to make the cutout in the baseboard for the outlet and the trim profile.
