Installing Frameless Cabinets
A step-by-step guide to fast and accurate kitchen installation
A step-by-step guide to fast and accurate kitchen installation by Bob Cox Installing frameless kitchen cabinets is a precise task. If you proceed logically and measure accurately, you’ll get good results. The following steps are a time-tested and proven method for properly installing frameless kitchen cabinets at controlled costs. Step 1: Check Specs Start out by fully familiarizing yourself with the details of the kitchen installation. Unfortunately, errors in paperwork or cases where the specs and the drawings differ occur too frequently. There is no better time than now to correct or adjust for discrepancies. Step 2: Check Materials A missing or damaged cabinet or part could delay installation. Depending on your past experiences with the supplier, you may want to unpack or unwrap each cabinet. If
