The Secret to a Perfect Baseboard Fit? A Preacher Block
When installing baseboard, don’t assume that door casings are perfectly square. Often, they are not, which means that you’ll need to somehow scribe the cut so that there aren’t any gaps between the baseboard and the casing. That’s where a preacher block comes in handy. In this short Instagram video, Chicago carpenter Marlon Rodriguez demonstrates how to get a perfect baseboard fit using a preacher block. The tip is just a sample taken from a longer tutorial that Rodriguez has posted on his Youtube channel, called How to Install Baseboard.
