Q&A: Construction Adhesives: Solvent- vs. Water-Borne
Three experts answer common questions about the sticky stuff
Q. Are there differences in performance between water-borne and solvent-borne construction adhesives?
A.Yes, solvent-based products tend to have a much faster curing rate, as well as a faster dry-down rate. They also have the ability to “wet out” some surfaces that a strictly water-borne product might not be capable of doing. An adhesive’s ability to wet out a surface is directly related to the ultimate performance of the glue line.
“Wetting out” is best explained using the analogy of waxing a car. If a car has been recently waxed, water will tend to bead on the surface. On the other hand, if it has been some time since a car has been waxed, water will form a film on the surface. At this point, the water is said to be wetting out the surface of the car.
It’s important to remember that most water-borne construction adhesives contain at least some percentage of solvent, which can often aid in their wetting ability.
— J.P.
