Cool Roofs for Hot Climates
Lighten the loads on home air conditioners with reflective roofing, radiant barriers, or better insulation and ventilation
14 MIN READ
Options for Stopping Rooftop Heat Gain
Field research at the Florida Solar Energy Center (FSEC) has found several effective ways to limit rooftop heat gain in sunny conditions. Using a highly reflective roofing material is the simplest and most effective: It stops the sun’s energy before any heat is absorbed, so that even the roof sheathing and framing stay cool. If the existing roof is dark colored or the customer prefers a darker roof, heat can still be blocked by adding a radiant barrier foil just below the roof deck. Savings from this method are roughly comparable to the saving achieved with reflective roofing; however, some conductive heating of the attic space will still take place, and the roof deck and shingles will experience some increased heat stress. A third option is to increase the insulation between the attic and the living space below, and to run the hvac ductwork within the conditioned space rather than in the unconditioned attic. This method has a smaller effect on cooling loads than the reflective or radiant barrier roof systems but is effective at reducing heating loads as well as cooling loads, making it the most cost-effective option in mixed heating and cooling climates.
