Maine Deck Brackets Are Easy to Flash Around
Offset Ledger Attachment Bolts to the house, allows siding to run behind by Mike Guertin It’s estimated there are two to three catastrophic deck failures each month; most are the result of a problem with the deck ledger connection to the house. Either the fastener system failed or a flashing problem rotted the rim board or the ledger, leaving the fasteners with nothing to hold on to. I was intrigued when introduced to the Maine Deck Bracket ($21), a deck ledger connection system that has been tested by the ICC Evaluation Service. Not only can you accurately determine that the
