Tricked Out
Truck accessories for pros at work.
7 MIN READ
Westin
Westin
StoryID
501509
ToolNumber
1
ComponentId
tcm:78-1627606
Westin
Made from polymer materials, these durable Splash Guards protect the vehicle’s finish from road debris. The guards, which can be painted to match the vehicle’s finish, contour to the wheel well and are designed to accent the vehicle’s lines. An optional polished Westin nameplate is available. 626-960-6762. www.westinautomotive.com.
Delta Consolidated Industries
Jobox High-Security Crossovers and Inner Side Boxes feature the company’s new Gear-Lock II, a locking system with dual, self-adjusting rotary gears that clamp onto a high-strength lid striker with 360-degree engagement to ratchet the lid tightly. The locks are tested to resist more than 2,000 pounds of pulling and prying force, the maker says. Other features include adjustable gas-spring-assisted lid lifts, built-in storage bins, and large lift-out tool trays. Crossover boxes (shown) mount across the bed of the truck and Inner Side boxes mount on top of the bed sidewalls; steel and aluminum versions are available. 800-643-0084. www.deltastorage.com.
A.R.E.
The company’s LSII fiberglass tonneau cover is now available for the 2007 Ford Sport Trac. According to the company, the cover is custom designed to match the Sport Trac’s contours, and it has a slide-on aluminum rail mounting system and corrosion-resistant clamps; the weight of the cover rests on the system’s rubber height adjusters, preventing paint wear on the truck’s bed rails. The cover can be unlatched with a twist of the handle, and the Lift Assist gas strut system makes it easy to open and close. Optional features include remote keyless entry and a battery-powered interior light. 800-649-4273. www.4are.com.
Dee Zee
The company has revamped the front wall of its toolbox body with Alumaguard, which protects the entire length of the rods and the latches from damage. Fully welded latch shields provide additional protection while still allowing the lid to close securely. The boxes have 34% more wall strength, according to the firm. Pricing remains as is. 800-779-2102. www.deezee.com.
Kramer Rack
With a space-age outer aerodynamic cover and an internal metal frame that integrates with the style of the truck, the Kramer Rack combines durability with a complementary, custom look. The steel frame is encased in polyurethane; it comes UV-protected in black and can be painted. The racks are rated for 1,200 pounds of evenly distributed loads and are adjustable for length and width for fitting to most foreign and domestic pickup models.770-455-6171. www.kramerrackplus.com.
Standard Hamilton
The Dump-Pro system, a dump insert for pickup trucks, is now available with the Hi-Sides option that increases volume from 2 cubic yards to 4 or 5 cubic yards. User-supplied 3/4-inch plywood sides are attached with a complete hardware system that is designed to “float” and automatically adjust to changes in temperature. The Dump-Pro unit features a Quick Change-Out option that allows the user to switch from pickup to dump truck in minutes. 866-438-6777. www.dump-pro.com.
Go Industries
Crafted from a single piece of 14-gauge steel tubing of 1.9 inches in diameter, the Big Tex Grille Guard is larger than standard 1-1/4-inch guards for extra protection from debris and brush. It will not bend, flex, or vibrate while in use, the maker says. The grilles have no-drill frame-mount installation, bolt-on light tabs, and rubber pads; headlight guards and a black diamond step are optional. They are custom-fit for full-size Chevy, GMC, Dodge, and Ford trucks and SUVs. 800-527-4345. www.goindustries.com.
Leer
The 800 series fiberglass tonneau cover for 2007 GM Silverado and GMC pickups features a newly designed quick-release hinge for easy removal, a center-mounted stainless steel key lock with a cover for weather resistance, a plastic shroud that hides linkage hardware, new rotary latches with optimal adjustment, and an EZ-grip rear style line. Keyless remote locking is optional. www.leer.com.
