Pennsylvania Builder First to Earn New
Green Standard’s Top Rating
A three-bedroom, 1,900-square-foot model home built by RGB
Custom Builders of East Stroudsberg, Pa., is the first
recipient of the National Green Building Standard’s
Emerald rating, the new program’s top certification. To
earn the Emerald rating, a home must be designed to use 60
percent less energy than a house that complies with the 2006
International Energy Conservation Code (IECC), plus meet other
criteria for efficiency, air quality, land use, and the
like.
Developed jointly by the NAHB and the International Code
Council (ICC), the National Green Building Standard (NGBS) is
based on the NAHB’s Model Green Home Building Guidelines,
first published in 2005. The standard — also known as
ICC-700 — was formally approved in January of this year
by ANSI, the American National Standards Institute.
Currently more than a thousand projects are in the
certification pipeline, says NAHB environmental communications
director Callie Schmidt. In addition to the Emerald rating, the
NGBS offers Gold, Silver, and Bronze compliance levels. To earn
an entry-level Bronze certification, a home would need to use
15 percent less energy than an IECC-compliant home.
Scoring. Viewed by some energy consultants as a more
user-friendly alternative to the U.S. Green Building
Council’s LEED for Homes (new construction) and ReGreen
(remodeling) rating systems, the NGBS can be used to rate all
types of residential construction work, including land
development, apartments and condos, and remodeling projects, as
well as new construction. Builders use a free online scoring
tool (nahbgreen.org/ScoringTool.aspx) to get a preliminary
score for their project, earning points in site and lot design,
resource, energy, and water efficiency, indoor environmental
quality, and building owner education. If the decision is made
to certify the project, the builder then submits a formal
application to a local third-party verifier who performs
rough-in and final inspections of the project. Certification
costs $500 ($200 for NAHB members); the verification fee is
determined by the verifier.
Compared with the old Green Guidelines (which are still
actively supported by the NAHB), the new NGBS is considerably
more stringent, with its Bronze rating roughly equivalent to
the older program’s Silver rating. In many ways it aligns
more closely with LEED, though some green builders argue that
the greater number of line items and higher number of available
points (1,200 in NGBS vs. 136 in LEED) make the NGBS a more
flexible program and should appeal to builders just testing the
green waters.
Earning 724 out of a possible 1,200 points, this
1,900-square-foot model home is the first to win the National
Green Building Standard’s Emerald rating, the
Cost. Bob Brown, president of RGB — the
Pennsylvania company that built the Emerald-rated model home
(see photo, above) — says that achieving the
certification added about $45,000 to the project’s costs,
raising the construction budget (not including land) from
$170,000 to $215,000. He attributes almost half that amount to
the home’s geothermal heating/cooling system and
energy-recovery ventilation. Flash-and-batt insulation —
consisting of a 1-inch layer of high-density foam followed by
fiberglass batts — added another $5,200 to the project.
— Andrew Wormer
Pulte Homes Buys Centex
Two large home-building companies — Pulte Homes of
Bloomfield Hills, Mich., and Centex Corp. of Dallas —
announced in April that they had combined, creating the
nation’s largest home builder. While the companies call
the $1.3 billion stock-for-stock transaction a merger, Pulte
shareholders will own roughly a 68 percent stake in the
combined business and the company will continue to use the
Pulte name and conduct business from Bloomfield Hills. With the
$1.7 billion it acquired from Centex as part of the deal, Pulte
doubled its cash reserve and greatly improved its chances of
surviving an extended economic downturn.
The Centex portfolio includes a number of buildable lots in
Texas and North and South Carolina, giving Pulte a strong
foothold in the entry-level market. Many analysts think that
first-time home buyers will help drive the housing recovery as
they take advantage of the federal $8,000 tax credit and
historically low mortgage rates.
In fact, some industry observers point to the merger as a sign
that the housing market has already started to recover.
“I can’t imagine them making a move like this if
they thought things are going to continue to
deteriorate,” said Paul Puryear of Raymond James &
Associates about the two companies in a recent New York
Times article. In May, share prices of home builders were
up slightly from January, with new-home sales continuing to
show signs of improvement. The NAHB/Wells Fargo Housing Market
Index — a measure of industry confidence — rose
from 9 in March to 14 in April and 16 in May. —
A.W.
Builders, Firefighters Continue Sprinkler
Battle
After more than two decades of heated debate, a controversial
fire-sprinkler provision for all new one- and two-family homes
was finally voted for inclusion in the 2009 edition of the IRC.
But with a January 2011 implementation date looming,
fire-safety groups are accusing home builders of trying to
preempt adoption of the code change by introducing
antisprinkler legislation at the state level.
Both Idaho and North Dakota have already passed bills that
limit the ability of local communities to adopt or enforce
requirements for home fire sprinklers, while a similar measure
was recently blocked in Illinois. In Texas, a bill is under
consideration that would limit enforcement of the sprinkler
requirement to homes larger than 7,500 square feet. According
to the National Fire Protection Association (NFPA), several
other states have bills pending that would revise the
membership of the state building code board, presumably to
stack the deck in favor of antisprinkler legislation (in Utah,
the position once held by a fire marshal was eliminated from
the state’s 11-member building-code commission).
In all, the NFPA cites at least 16 states that currently have
antisprinkler legislation on file (for a list and more info, go
to the association’s Web site, firesprin
klerinitiative.org). — A.W.
Canadians Raise the Roof on Wood-Frame
Buildings
In April, British Columbia raised the height limit for
wood-frame residential buildings from four stories to six. The
change was part of a package of proposals designed to help the
Canadian province’s struggling forest industry, among
them a slash in the stumpage rates (fees private companies pay
to cut government-owned timber) and a requirement that public
facilities be built with local timber whenever possible. The
proposals were announced earlier this year by B.C. premier
Gordon Campbell.
In support of the height change, a government analysis noted
that Seattle, Portland, and several other U.S. jurisdictions
already allow five-story wood-frame buildings. But some groups
in the province charge that the code change was politically
motivated and adopted without sufficient study of structural
and other issues. The Fire Chiefs’ Association of British
Columbia, for instance, argues that fire departments lack the
resources and training to fight fires in wood-frame buildings
taller than three or four stories. And professional groups of
architects and engineers warn that the walls of tall wood
buildings are subject to elevated moisture loads and high wind
forces that increase the risk of leaks.
Despite these concerns, Campbell says he would eventually like
to see Canada’s National Building Code adopt the measure.
“Adopting a national building code that permits wood
structures for buildings up to six stories ... would expand
demand, help the environment, put people to work in forestry
and construction, and save taxpayers millions,” he said
in a statement to the National Post, a Canadian
newspaper.
Offcuts
In an effort to spruce up some of its distressed neighborhoods,
a California town has hired a contractor to spray-paint bare
spots on the lawns of vacant properties. The contractor uses a
water-soluble, environmentally friendly green dye and charges
about $550 per lawn. Since the dye lasts only six months or so,
the town is hoping the foreclosed properties are purchased
before the lawns need a touch-up.
A basement remodeling
company once honored by Connecticut’s Better Business
Bureau faces charges that it ripped off customers and failed to
pay subs and suppliers. The charges were brought by Attorney
General Richard Blumenthal, who presented Custom Basements
owners Nicole Kiesman and Shelly Dacey with the BBB’s
Torch Award for ethical business practices last fall. Bilked
customers say the company used the award to convince them to
sign up for remodeling services they never received. Custom
Basements has since filed for bankruptcy, blaming tough
economic times and citing nearly $500,000 in debts — but
a former sub says the owners spent money on expensive perks
like extensive office renovations and company cars. Blumenthal
has asked the BBB to explain how it chooses its award
winners.
