The Latest Twist: Crisscross Build-Down
On a recent house, we tried a new build-down method that
doesn’t require gussets. Under 2x12 rafters, we simply
used 31/2-inch pneumatic nails to spike 2x3s on edge
perpendicular to the rafters (Figure 4).
| Figure
4. The author’s newest method is to
spike 2x3s on edge crosswise to the rafters (top
left), install a reinforced vapor barrier and
strapping (top right), then blow the cavities with
cellulose (left). |
Again we installed a reinforced poly vapor barrier and
strapping (this time, the strapping went parallel to the
rafters), and blew the cavity full of dense cellulose.
Subtracting 3/4 inch for the vent channel, this gave us a
13-inch thickness of cellulose, including a 21/2-inch thermal
break below the main rafters — a good R-49.
This particular roof was more a cape than a cathedral: There
was a small, flat ceiling at the top, and a kneewall halfway
down the roof plane from that. But as in a straight cathedral
roof, we insulated the rafter cavities all the way from the
upper attic section to the eaves — the space behind the
kneewall stayed within the insulated space.
This technique was simple and effective, and I plan to use
it again. However, next time it involves a kneewall, I’ll
do that part differently. Last time, we framed the kneewall
before building down the rafters, which created complications
with the vapor barrier (Figure 5).
| Figure
5. In the case shown, a kneewall complicated the
vapor barrier installation (photo, left). To prevent
that, the author recommends first insulating the entire
roof plane down to the eaves, then building the
kneewall. Besides giving a 13-inch-deep insulation
cavity, the crisscross build-down also provides a
21/2-inch thermal break below the rafters
(illustration, above). |
In the future, we’ll build down the rafters first,
install a 3/4-inch plywood plate spanning two build-down
pieces, then frame the kneewall to that plate.
Of all these methods, the only one I wouldn’t use
again is the first — to my mind, I-joists for rafters
aren’t worth the hassle. Of the other three methods,
I’d use whichever one best suits the particular case.
Building down with gussets is great for a large expanse of
ceiling, where the work goes quickly — and you can get an
almost unlimited thickness of insulation. Our new crisscross
build-down method is also quick and simple, as long as you plan
ahead for vapor barrier and strapping details. And although the
foam-face and batt method isn’t the best or the cheapest
technique, it gives decent results quickly on a small
ceiling.
But like I say, I’m still experimenting. If
anyone’s got a better idea, I’d love to hear
it!
