by Mike
Guertin
In the Ocean State — where wind-swept rains aren't restricted
to nor'easters, tropical storms, and hurricanes — I count on
a vented rain screen coupled with carefully detailed flashings to
keep water out of walls.
A rain screen is a cladding system with a vent space (or a
series of vent channels) between the back side of the cladding and
the weather-resistive barrier. Openings along the top and bottom of
the vent space let air flow freely. This vent space provides a
channel for any water that gets past the cladding surface to drain
out, and the air flowing through this space carries away moisture
vapor that dries off the back side of the siding. In both
instances, the vent space reduces the chance of water and moisture
vapor being driven into the wall cavity by wind or sunshine.
Installing any cladding as a vented rain screen is the best way to
make the cladding last. However, it's easier to do with lap sidings
than with shingles. Lap siding, such as cedar clapboard and
fiber-cement planks, easily bridges air channels between vertical
furring strips nailed over studs. But a vented rain screen with
sidewall shingles requires horizontal furring, which presents some
complications.
Rain-Screen Options
I've built cedar-shingle rain-screen sidings in three ways. The
differences mostly involve the material that forms the vent space,
but this inevitably affects other details as well.
Vented furring strips. The first time I built a cedar-shingle
vented rain screen, I laid shingles over a series of back-kerfed
1x3 furring strips (Figure 1). These back kerfs are essential for
allowing drainage and airflow between the horizontal strips, but
they take a considerable amount of cutting and time: I mounted a
dado blade in a radial arm saw and cut 3/8- by 3/8-inch kerfs a few
inches apart along what seemed like thousands of 12-footers. I then
nailed the furring strips over the housewrapped wall sheathing,
positioning each strip above every butt line on each course of
shingles. The shingles went up fine, but I didn't plan my window,
door, and corner trim details very well. Shingle butts stood proud
of some trim elements, and I cobbled together less-than-perfect
solutions to mask other problems caused by the 3/4-inch furring
thickness.
Figure 1. The author's first experiences with
venting shingles relied on back-kerfed 1x3 furring strips. These
back kerfs are essential for allowing water to drain out and air to
flow between the horizontal strips, but cutting the kerfs with a
dado blade in a radial arm saw proved too labor
intensive.
Fortunately, there are now a couple of commercial products
available for creating vented rain screens with shingles. I've used
both nylon spacer mats and plastic battens over the past few years
and found advantages and disadvantages with each. I also worked out
details for windows, doors, and trim for these rain-screen systems,
as described below.
Spacer mat. Home Slicker by Benjamin
Obdyke is the best-known spacer mat available. It's marketed
specifically for use with sidewall shingles and lap siding, though
other companies make similar products for EIFS and masonry walls
that will also work with shingles (see "Resources,"). Home Slicker
is a corrugated matrix of nylon strands about 3/8 inch thick that
comes in approximately 40-inch-wide rolls. It gets applied with
staples or cap nails over housewrapped walls, and the matrix
compresses a little when the shingles are installed on top, leaving
an effective 1/4-inch air space. The corrugations should be
oriented vertically for the best drainage and airflow, and the
edges of the mat should not be overlapped.
A spacer mat such as Home Slicker goes up quickly with no special
layout, creating a 1/4-inch ventilation gap behind shingles. It is
important to cut Home Slicker close to trim such as window casing
and corner boards: If you leave a space wider than about 3/4 inch,
the unsupported shingle edge is likely to split.
On the plus side, Home Slicker is only 1/4 inch thick — not
nearly the 3/4 inch my furring strips padded out the shingles. The
butt lines of each shingle course laid over Home Slicker flush out
with 5/4-inch corner boards applied directly over the housewrap.
And the butt lines come close to, but not past, most flanged window
jambs. The sheets go up quickly with no special layout, but it is
and corner boards. If you leave a wide space (3/4 inch or more),
On the downside, fastening shingles over Home Slicker takes a deft
hand. The bottom few shingle courses are the hardest to install.
The matrix is spongy, so hand-driving nails is a challenge, and
pneumatically driven staples or nails easily overdrive even with
the air pressure set low. You'll end up splitting more shingles in
the first two rows than on the rest of the wall. Subsequent courses
are supported by the shingles beneath, so the going gets a little
easier. There's a noticeable cushioning of hammer blows when
hand-driving nails into shingles applied over Home Slicker. The
bounce makes it hard to start nails in the shingles. You must also
use fasteners long enough to pass through the vent space and
penetrate all the way through the sheathing.
Plastic battens. Corrugated plastic
battens offer a good alternative to my furring-strip rain screen.
These have hollow channels that let water and air flow through them
(Figure 2).
The only ones I've found marketed specifically for shingle
installation are those from DCI Products — CedarVent and
RafterVent — but similar products are available (see
"Resources"). Standard CedarVent comes in strips 3 feet long. The
four-ply version is 3/4 inch thick by 2 3/4 inches wide. But a
two-ply version that's just 3/8 inch thick (my preference) and a
three-ply version that's 9/16 inch thick are also available. While
1 1/2-inch-wide strips can be special ordered, I typically just rip
the two-ply version in half (from 2 3/4 inches down to 1 3/8
inches) to save material and expose more of the shingle back to the
air. CedarVent is wrapped with a thin fabric to keep insects out,
so it's great along the undercourse at the bottom of the wall and
last course at the top. RafterVent can be used instead of CedarVent
in the field of the wall. It's essentially CedarVent without the
fabric wrap.
Battens require precise placement, so they aren't as fast to
install as spacer mats, but they do provide solid support for
nailing. I lay out a story pole for shingle course exposure and use
it to mark locations for the battens. After I transfer these layout
marks onto window and door trim and corner boards, I snap chalk
lines on the housewrap between my marks. The battens get applied
above the lines. Since shingles are nailed about 1 inch above the
butt line of the overlapping course, the battens are positioned
perfectly behind the nail line. Extra battens are needed under
windowsills and horizontal band- board trim elements to support the
top edges of the shingles.
Figure 2. Plastic battens have hollow channels
that let water and air flow through them. Shown here is the two-ply
version of CedarVent, which the author rips to 13/8 inches wide to
air.
Other than selecting longer fasteners, there's no special
precaution to applying shingles over battens.
Trim Details
The devil is always in the details. Corner boards, woven corners,
window and door trim, band boards, and other trim elements must be
planned to account for the extra thickness of the rain-screen
"sandwich." I address some of the challenges this presents here,
but this is by no means an exhaustive list. It will, however, give
you a foundation to come up with your own solutions for those
yet-to-be-encountered trouble spots.
Pests and nests. Wasps and hornets love
to make nests in rain-screen spaces, so along the bottom (intake)
vent slot and the top (exhaust) vent slot you need to block bug
entry. Simple strips of insect screen wrapped around the edge of
spacer mat or battens are all you need. Slicker Screen is a
companion to Home Slicker, and DCI's CedarVent already has an
insect-blocking fabric covering. When I'm not using those products,
I staple 3- or 4-inch-wide screen to the bottom edge of the wall
before installing battens or spacer mat (Figure 3). After the vent
material is applied, I wrap the screen onto the face and staple it
in place. Once the trim or shingles are applied, the screen is
trapped securely.
Figure 3. Wasps and hornets love to build
their nests in the vent space of any rain screen, so exposed edges
(at the bottom and top of walls and over windows and doors) must be
protected with screening.
Weaving shingle corners. Hand-weaving
outside and inside corners over Home Slicker is a challenge. The
shingles drift a little when planning, because the fastener shanks
flex in the air space and the sponginess of the matrix makes it
hard to keep the shingles from moving around. Rather than get
frustrated, I avoid the issue by wrapping outside and inside
building corners with 6-inch strips of 1/4-inch plywood. The
plywood gives solid support for fastening and provides crisp lines
to plane the shingle edges to. For extra weather resistance, I
staple 16- to 24-inch-wide strips of housewrap or building paper
over these plywood backing strips, letting it lap over the edges of
the Home Slicker.
Plastic battens don't pose the same trouble because they're more
stable. I run the battens around the corner and weave the corners
like normal. The only tricky part is starting the first two courses
at the bottom; but once they are secured, the rest of the corner
shingles go fine.
Corner boards. Ideally, corner boards and
other trim elements should be applied over the rain-screen space.
They benefit from the drainage and "back-venting" just like the
shingles. Plus, installing the trim over the vent material keeps it
in the same plane as the shingles. However, this is practical only
over battens. Over the less stable spacer mats, the corner boards
are hard to line up.
One way to deal with this is to apply 1/4-inch plywood or OSB
spacers to the building corner, which provides solid nailing and a
vent space (Figure 4). I use 4-inch-wide plywood or OSB spacers
positioned 12 to 24 inches apart up both sides of each building
corner. I cut the block width 1/2 inch greater than the
corner-board width and snap vertical plumb chalk lines over the
blocks that give me a reference for aligning the corner boards.
These spacer blocks are easier to install before the matrix mat is
installed. There's no need to cut the mats around the blocks either
— just trim at the outside edge.
Figure 4. Corner boards should be applied over
a rain screen just like the siding. While this is relatively easy
with battens, installing trim over a spacer mat is more difficult
because the pliable mat doesn't provide a stable nailing base. To
make it easier, the author installs 1/4-inch OSB spacers to the
building corner before the matrix mat is installed.
Horizontal band boards or skirt boards present a similar challenge.
I treat them the same as corner boards. With battens, I run one
strip at the bottom and one at the top, which is placed so half the
batten supports the top edge of the board and the other half is
exposed to support the first course of shingles. When using spacer
mats, I install blocking as a base for the band boards, just like
the corner boards (Figure 5, page 5).
Figure 5. Skirt boards over a spacer mat also
get 1/4-inch plywood or OSB blocks (far left), while battens are
simply spaced so half the batten is above the top edge of the skirt
board (left). In both cases, a drip cap flashing must be installed
over the horizontal trim board, but this flashing should not extend
to the sheathing so it will not disrupt airflow.
Regardless of the material used to create the vent space, you still
need to install drip cap flashing over horizontal trim. But don't
run the drip cap all the way to the wall sheathing over the band
boards. Doing so will break the continuity of the airflow. Instead,
treat the cap flashing like a Z flashing, as shown in Figure 5. Its
main function is to redirect water that enters at the siding/trim
joint back out and protect the top edge of the band board. Run the
"wall" leg of the flashing over the face of the rain screen so air
can freely flow from intake to exhaust.
Windows and doors. Over windows and
doors, the flashing practice is different. Run cap flashings all
the way to the wall sheathing and integrate with the housewrap
(Figure 6). Any water draining in the vent space will drain out
over the drip cap. Be sure to leave a 3/8-inch air space between
the bottom of the shingles and the cap flashing for air
circulation. And remember to provide insect screens on the
rain-screen material.
Figure 6. The best way to handle the exterior
trim is to mount the window flange on furring strips (far left).
The alternative is to fur out for the window trim after the window
is installed (left), which works with a 1/4-inch to 3/8-inch spacer
material.
Keeping the vent space thickness down to 1/4 to 3/8 inch doesn't
pose much of a problem. However, if thicker drainage mats or
battens are used (3/4 inch, for instance), the windows and doors
will need to be padded out. The simplest fix is to mount spacer
blocks around the rough openings that equal the thickness of
whatever spacer material you're using. Some builders don't like
this solution because it requires extension jambs to pad the window
and door jambs flush with drywall on the inside. But if you're
framing 2x6 walls, or using windows with 2 1/4-inch-deep jambs in a
2x4 wall, then you're ripping extension jambs anyway, so there's no
extra labor and minimal materials.
Exhaust-Vent Detailing
Don't forget to provide a route for the rain-screen vent space to
exhaust along the top. I've used two different details:
Frieze-board vents require only a little
advance planning and can be incorporated after the soffit board has
been installed. Leave a 1/2-inch space between the last batten and
the soffit board, and cut the top of the shingles about 1/2 inch
short of the soffit as well (Figure 7). Then use blocks
approximately 3/8 inch thick to space the frieze board off the
surface of the shingles. In order to keep the frieze plumb, I rip
tapered blocks to apply over the shingles at 16-inch centers. Air
flows freely between the rain-screen space and the space behind the
frieze.
Figure 7. The vent space in a rain screen
needs an air exhaust along the top. This can be detailed in two
ways: (1) by venting the space into the soffit (above left), or (2)
by using a vented frieze board (above right).
Vented soffit. With a little more
planning, you can eliminate these tapered spacers, and just let the
rain screen exhaust into a vented soffit. Cut the soffit board 1/2
to 3/4 inch narrower than the fascia-to-wall dimension, so there's
a gap between the back edge of the soffit board and the wall
sheathing. This allows you to run the rain-screen material right up
to the soffit space, and the frieze board will conceal the gap. Air
can then flow freely from the rain-screen vent space and into the
soffit. ~
Mike Guertin (www.mikeguertin.com) is a custom home builder and
remodeler in East Greenwich, R.I., and a member of the JLC Live
Construction Demonstration Team leading sidewall shingling
workshops. All photos by the author. Illustrations by Chuck
Lockhart.
