The 2009 International Residential Code (IRC), due to be
published March, will contain some significant revisions to the
provisions governing bracing of walls against racking forces in
moderate wind speed zones.
In wind speed zones of 110 mph and higher, the IRC requires
engineered wall design — either a full analysis using
ASCE 7 (the American Society of Civil Engineers standard for
building design), or else a design that follows one of the
prescriptive cookbooks based on ASCE 7, such as the
Guides to Wood
Construction in High Wind Areas published by the American
Wood Council.
But for design wind speeds up to and including 100 mph,
builders can rely on methods written right into the IRC. And
the rules allow a lot of latitude: You don't have to fully
sheathe a building in wood structural panels (plywood or OSB)
— you can use a wide range of methods, including wood
or metal let-in bracing, gypsum board, or a smaller number of
wood panels in strategic locations.
Source: APA - The Engineered Wood
Association
The 2009 IRC will offer multiple ways to brace walls in
moderate wind-speed zones, including this updated version of
the "portal frame" assembly developed by APA - The Engineered
Wood Association. The closely-spaced fasteners and the
extension of the header past the door opening into the sheathed
wall create a stiff elbow at the corner of the frame that acts
as a moment-resisting connection. Anchors and metal tie-down
straps add to the strength of the assembly, and allow a narrow
section of wall to effectively brace the structure. The new
code is slated to be published in March 2009, but will only
take effect after adoption by state and local
governments.
But all that flexibility comes at the price of a lot of
confusion in the code. For years, an International Code Council
"Ad
Hoc Committee on Wall Bracing" has been working to simplify
the code language and organize the requirements into a more
coherent presentation. The committee has also struggled to come
to grips with some substantive structural issues. Coastal
Contractor took a look at the wall bracing provisions of the
2006 IRC in an article entitled
Wall Bracing and the IRC. But as states and localities
adopt the updated 2009 edition of the IRC, some of those rules
will change — and builders will have to get current on
the modifications.
Jay Crandell, a consulting engineer who worked for years at the
NAHB Research Center and is now principal of
ARES Consulting in
West River, Md., is a member of the wall bracing committee.
Crandell says that the 2009 rules are an upgrade in terms of
presentation. For example, to make the code more user-friendly,
code tables will now spell out the length of "braced wall
segments" in feet, rather than in percentages that require the
builder and code officials to do the math.
But there are also some important technical changes:
New bracing tables for wind loads. The 2006
code uses the same table for wind loads and seismic loads,
Crandell notes. This is not a big deal for small houses, but
the bracing amounts could be inadequate for big houses with a
lot of "sail area" for wind to work on. The 2009 code will have
separate tables for wind and seismic loading — which
means big buildings may need to have better bracing under the
new rules. But the committee took considerable pains to make
sure that the new rules were not unrealistically conservative.
"Making this work without penalizing smaller homes and typical
modest-sized homes in low-wind regions required some effort to
develop new engineering methods and data that better agreed
with experience and actual whole-building performance," says
Crandell. The committee spent a long time hashing out a way to
account for building elements such as interior walls, drywall,
and siding that add strength to walls but tend to be ignored by
accepted engineering methods. The older methods, says Crandell,
"consistently under-predicted actual whole-building system
strength by more than a factor of 2."
New uplift requirements. "When substantial
wind uplift is transferred through braced walls, it has the
compounding effect of weakening the strength of the bracing,"
Crandell explains. To address this, the 2009 code will call for
anchors and for uplift strapping between upper and lower story
walls, "but mainly for longer roof spans on larger buildings in
the higher wind regions of the IRC (greater than 90 mph)," says
Crandell.
Mixed bracing methods. The 2006 code is
unclear on whether different walls on the same building can use
different materials to meet their required bracing amounts. The
2009 code will spell out that a builder can, for instance, use
plywood on one house wall and let-in bracing on another wall.
Similarly, builders will also be allowed to use one bracing
system on a lower story and a different system on an upper
story.
More versatile "portal frames." The 2006 code adopted
a method for stiffening the wall area around window or door
openings called a "portal frame," which used close nail spacing
and beefed-up framing to stiffen narrow walls near big
openings. The 2006 version is only permitted in fully sheathed
walls, but for 2009, officials have approved a portal frame
method for use in walls with only partial wood sheathing.
Hold-down and anchor requirements for the portal frame method
have also been reduced.
Even with the improvements, the IRC wall bracing provisions are
still complicated. Crandell says the committee is already
starting work on a 2012 revision, with the goal of further
tidying up the presentation. Plus, he says, the committee hopes
to develop a "bracing light" version that can be used for
simpler homes, "without having to wade through the many options
of the current bracing provisions, which are designed to
capture a broader set of conditions but which add much
complexity to the code that many users don't need."
Many builders, of course, fully sheathe their houses as a
matter of course, and some wouldn't build any other way. But
the code's multiple options for bracing are rooted in
historical building practice from many regions. They're also
backed by industries such as the rigid foam sheathing
manufacturers, who have set up a "Foam Sheathing Coalition" to
advocate for wall construction methods that work well with
rigid foam. The Foam Sheathing Coalition has followed wall
bracing code development closely, and it's a good source of
information on the ins and outs of the code requirements, as
well as some of the technical data behind the code engineering.
Foam sheathing, of course, can be an effective component in a
high-performance energy-efficient building, so builders may
want to take a closer look at the foam industry's views on
structural issues. For information, check out the
FSC website
