Crawlspace Insulation & Fire
Codes
To the Editor:
I found the article on conditioned crawlspaces
("Building a Sealed
Crawlspace," 10/03) very informative. As a building
inspector in New Jersey, I have promoted this concept for
years. The only disturbing thing about the column is that the
use of uncovered rigid insulation in crawlspaces is prohibited
due to the smoke development ratings.
Thank you.
Matthew O'Hara
Barrington, N.J.
Author Jeff Tooley responds: Our company has run into the
fire code issue in our crawlspace work. Here's where things
currently stand: Building departments in our area used to allow
exposed extruded polystyrene to be applied over framing or
concrete in unconditioned spaces. But once they realized that
we were making the crawlspace a conditioned space, they started
to require a fire-rated foam board. In response, we now use
Dow's Thermax, which meets local code requirements, and we are
not required to cover it.
Thermax is a polyisocyanurate foam; it doesn't melt and has an
ignition point near 800°F. It has foil facing on both
sides and is reinforced with fiberglass, which makes it
sturdier and helps it achieve a 15-minute fire rating.
When the building departments cracked down on the pink and
blue foam board, we had to go back to some homes under
construction and cover installed board with drywall. I don't
recommend drywall in a crawlspace at all, and the code allows
other coverings (metal, wood, and rock wool), but I left that
decision up to the builders who were paying for the work. Any
covering is inconvenient and awkward, so we stick to Thermax,
though any brand with a similar fire rating would
work.
Nail Gun Injuries No
Accident
To the Editor:
I read with great interest Ted Cushman's article on nail gun
injuries (In the
News, 10/03), in which he reported information from a study
on nail gun injuries among residential carpenters. I conducted
the study and would like to clarify issues raised in Mr.
Cushman's report.
First, Mr. Cushman wrote that inexperience was reported as an
important risk factor in our study. We did report a higher
injury rate among apprentice carpenters (3.5 times higher than
journeymen). This rate was based on the total hours each
carpenter worked but not the hours they actually were using a
nail gun. We believe the use of these tools is often considered
a relatively unskilled task assigned to inexperienced workers,
and we found evidence that apprentice carpenters use the tools
more of the time than more experienced carpenters. It is
important not to attribute the higher rate solely to
inexperience when it may, in fact, be a reflection of their
greater use of a potentially dangerous tool.
As Mr. Cushman reported, we recommend formal training for
carpenters who use these tools. A number of injuries were the
result of a carpenter firing the tool back toward himself,
using his nondominant hand, poor placement of the non-firing
hand, working in an awkward posture, and lack of eye
protection, for example. However, we tried to emphasize how our
findings support the need for engineering and policy changes to
prevent these injuries. The majority of the injuries we
investigated (68%) would likely have been prevented if the
carpenter had been using a tool with a sequential
trigger.
Our study was conducted before the industry-sponsored ANSI
standard change (effective May 2003), which calls for the
shipping of framing nailers with sequential triggers instead of
contact trip mechanisms. Users can still request a contact trip
mechanism. Based on our data, we would like to have seen the
contact trip discontinued, but this is at least progress.
Suppliers will often retrofit existing contact trip guns with
sequential triggers, sometimes at no charge.
We know there are concerns on the part of contractors and
carpenters about slower production with the use of
sequential-trigger tools. We are interested in studies that
look closely at this issue in a broader context; speed in
sheathing may be offset by costs of extra nails resulting from
unintentional firings of contact trip guns, poor construction
quality, and costs of workers' compensation claims for
injuries. We recently reported that nail gun injuries, along
with injuries from falls, setting steel beams, and lifting
framed walls, were among the most costly work-related injuries
in residential carpentry (Journal of Occupational and
Environmental Medicine, 8/03). Because many of these
injuries involve relatively minor puncture wounds, their
potential seriousness is often dismissed.
Finally, I find the use of the term "accident" to describe
these injuries worrisome, because it implies that a random
event has happened. These are not accidents, they are
preventable injuries. It does not make sense to focus
prevention on the training of workers in the use of a dangerous
tool. The tool should be changed instead! We are smart enough
to prevent many of these injuries, and we should.
Hester J. Lipscomb, Ph.D.
Associate Professor, Occupational and Environmental
Medicine
Duke University Medical Center
Durham, N.C.
Commonsense Installation
To the Editor:
In the November 2003
Q&A, your
expert advises against venting a bathroom fan through the
soffit at the eaves because the moist air will "most likely" be
drawn back into the attic.
A dose of common sense might be in order. If the fan has any
kind of velocity at all, will that moist air really make a hard
U-turn and streak into the attic? And if the suction up toward
the ridge is that impressive, will the moisture even have time
to condense on a cold surface before it blasts out the ridge
vent? I'm wondering if I need to fit my cap with a chin strap
the next time I'm working near a soffit vent.
So many bathroom fans are either poorly vented (into the attic
or a joist bay) or not vented at all, getting that moist air to
the outside, even if it's in proximity to the soffit vent, is
an improvement.
Arne Waldstein
Arne Waldstein Construction
Housatonic, Mass.
Likes Fiber Cement
To the Editor:
I liked your article on fiber-cement board
("Installing
Fiber-Cement Siding," 12/03); it's nice to see that there
is someone else out there who installs correctly. I'm in the
siding business in Wisconsin. We do a few big homes on Lake
Michigan each year in Hardiplank. It is by far a superior
product compared to others. You can mix and match your corner
boards, light blocks, and other components. When we want higher
definition at the corners, we use MiraTec, which blends well
with Hardiplank. There is really no limit to what you can do
with this product.
Randy Westphaln
R.W. Siding Specialist
Twin Lakes, Wisc.
