Builders are beginning to hear more complaints that
traditional masonry fireplaces leak smoke and burn too much
wood for too little heat output. The fact is, open site-built
masonry fireplaces have always been filthy, smoky, and
inefficient, but these drawbacks were less noticeable in
drafty, uninsulated houses. Today’s tighter homes,
however, are less forgiving, and their occupants are less
tolerant.
In addition, many modern fireplaces are used strictly as a
design element, and many designers have no training in what
makes one work. On top of that, many of the masons and other
heating contractors who build fireplaces carry over outdated
design traditions that are at the root of performance
problems.
It doesn’t have to be that way. Building scientists
now understand why traditional fireplace designs perform
poorly, and masons, manufacturers, and hearth installers have
responded with new products and techniques that eliminate past
problems.
In this article, I’ll discuss the common causes of
fireplace problems, and propose solutions for masonry
fireplaces and heaters, as well as less expensive, efficient
wood-burning metal fireplaces.
Why Fireplaces Fail
When
it comes to traditional open masonry fireplaces, masons have
perpetuated outdated ideas about the smoke shelf, the mysteries
of the smoke chamber, and the need for wide, but shallow-throat
dampers.
Today, it is clear that all three of these features work
against successful fireplace performance (see Figure 1).
Figure
1. Traditional fireplaces leak smoke into living space
and don’t produce heat efficiently. The curving smoke
chamber, the throat damper, and the smoke shelf all decrease
the stability of the chimney draft.
The smoke shelf and shallow-throat damper both act as
obstacles to straight exhaust flow. And the smoke chamber
actually reduces the strength of a chimney’s draft by
slowing and cooling the fireplace exhaust. The performance of
many brick fireplaces can be improved immediately by removing
the throat damper and smoke shelf, and installing a
chain-operated damper at the top of the chimney. The results
are a smooth, straight path for the exhaust and less smoking
when a fire burns.
