Controlled Combustion
The design of the fireplace itself plays a big role in the
level of satisfaction it provides. The internal features that
produce efficient, smokeless combustion tend to be the same as
those that produce reliable chimney venting and trouble-free
operation. To help guide fireplace design, here is a simple
rule of thumb that neatly summarizes a lot of expensive
research: The more air a fireplace demands for normal
operation, the more fussy and spillage-susceptible it will
be.
Open fireplaces are the worst because they consume huge
amounts of air — much more than is needed for combustion
— which cools the system, thereby reducing draft. If your
clients insist on a traditional fireplace, make sure they also
agree to equip it with tightly sealed doors. The more you
control the combustion in the firebox, the higher the
temperatures of the exhaust and the stronger the draft.
If your client doesn’t want glass doors or much heat,
direct them to a gas hearth. Do the same if the
architect’s plans call for a hearth in an outside chase
situated at the low eaves of a cathedral roof. If the clients
cannot be convinced to relocate the fireplace more centrally,
you will both probably be happier with a direct-vent gas
fireplace.
Several other alternatives to traditional masonry fireplaces
are also available. Metal stoves and fireplaces that meet
Environmental Protection Agency (EPA) rules for low smoke
emissions are the most resistant to leaking smoke into the
house because they create a reliable draft (Figure 5).
| Figure
5. The Delta prefabricated metal fireplace
is one example of an EPA-certified
controlled-combustion fireplace (International
Chimney Co., 400 J.F. Kennedy, St. Jerome, Quebec,
Canada J7Y 4B7; www.icc-rsf.com;
450/565-6336). |
These appliances are equipped with internal baffles, firebox
insulation, and strategically placed combustion air inlets,
which produce a stable, clean-burning fire, even at low heat
output settings.
Don’t sacrifice performance for lower cost, however.
Some cheap units are made out of lighter, thinner materials,
and are often connected to lightweight air-cooled chimneys with
flue diameters that are too small relative to the fireplace
opening. All of these cost-saving elements hurt
performance.
For customers who insist on a real brick or stone fireplace,
a masonry heater is a good option (Figure 6).
| Figure
6. Masonry heaters, with their enormous
thermal mass, are designed to burn very hot, then
store and slowly release heat. Although more
expensive than prefabricated metal fireplaces, they
provide a reliable high-performance wood-burning
hearth. |
Masonry heaters use rapid combustion and heat stored in
their massive structure to achieve high efficiency and
excellent resistance to spillage.
Both types of appliances solve the smoky fireplace problem
because they get hot and stay hot until the fire fades to a
coal bed and goes out. Both types also produce net efficiencies
of more than 60%, a welcome feature during a winter electrical
power failure. In addition, high-quality prefabricated metal
fireplaces are much less expensive than traditional masonry
fireplaces — often less than half the cost, depending on
the facade and mantel design (Figure 7).
Figure
7. Metal fireplaces don’t have to look metallic.
The masonry surround for this metal fireplace gives a
traditional look along with predictable performance, at a
savings over a site-built masonry fireplace.Trained Installers
In the
last 20 years, building science research has clearly shown how
fireplaces behave in houses. These insights are now being
promoted through professional training programs. When planning
a traditional masonry fireplace or metal heater, or even a wood
stove, use suppliers, installers, or masons who understand the
pitfalls of outdated ideas and impractical designs. Fireplace
suppliers and installers who are graduates of the Hearth
Education Foundation courses (www.hearthed.com; 716/343-6524)
have a better handle on the issues that concern builders than
those who are untrained. If a masonry fireplace is required,
use only qualified heater masons who are certified under the
Masonry Heater Association professional training program
(mha-net.clever.net; 802/728-5896).
John Gulland is a hearth consultant based in Ontario,
Canada. He is author of The Fireplace in the House as a
System.
