Replacing Factory-Built Fireplaces, continued
Out the front. If the trim
around the front of the fireplace is easy to remove, we just
pop it off, cut or remove the fastenings that hold the unit to
the framing, and pull it out of the opening (Figure 4). If
there's no easy way to remove the trim and no good access from
the back, we sometimes resort to cutting the fireplace apart
with a recip saw and removing it piece by piece.
Figure 4.The simple three-board facing around this
circulating fireplace was easily removed without damage, making
it possible to slide it forward into the living space for
removal.
Removing the flue. When a
fireplace is installed in an exterior chase, the flue sits
directly on top of the unit and runs straight up through the
chase cover. If the flue is less than 28 feet long, there's
usually no need to anchor it to the framing anywhere else,
making it easy to remove by pulling it straight up.
In interior applications, the old flue can be harder to get
at. Concealed indoor flues often need to be routed around beams
or other framing obstructions, which requires the use of offset
elbows provided by the manufacturer (Figure 5). The offset
elbows are sold in pairs, usually in angles of 15 or 30
degrees. The manufacturer will specify how many offsets can be
in a chimney (typically two pair) and how far they can be
spaced.
Figure 5.When flue offsets are used to route the
vent stack around obstructions, the attached metal straps are
nailed or screwed to the framing to support the weight of the
chimney above. Offsets in an existing flue slated for removal
are easy to deal with if they're located in an attic or other
accessible area, but if they're enclosed in a finished wall,
it's sometimes necessary to cut additional holes to reach
them.
In With the New
We encourage our customers to think carefully about what they
want before they choose a replacement fireplace. Do they want
an efficient heating appliance, or do they just want to look at
a fire a few times a year? Do they really want to deal with
wood, or would they be happier with the convenience of gas?
It's a frustrating experience to install a wood-burning
fireplace only to have the customer retrofit it with a set of
aftermarket gas logs as soon as we finish. Manufactured gas
fireplaces are much more efficient than such conversions, and
not that much more expensive.
Clearances and standoffs.
Although prefab fireplaces are sometimes called "zero-clearance
fireplaces," that is a misnomer. The installation manual that
comes with each unit will specify the required clearances to
combustibles, which must be followed to the letter. Most
fireplaces also have attached triangular "standoffs" that
physically prevent the top of the unit — the hottest
part during use — from coming too close to the
framing. Those should never be flattened or removed to allow a
fireplace to fit an existing opening (although we often remove
older units that have been modified in that way).
The firebox of a typical modern prefab is 36 or 42 inches
wide, and the unit requires a 46- or 52-inch rough opening. The
older models we replace generally required somewhat larger
rough openings for a given firebox size. That's helpful,
because it means we can usually install a fireplace the same
size as the original without having to cut away surrounding
combustibles.
Prefab fireplaces are designed to sit directly on the
combustible floor, but that makes me a little nervous. I
usually put down a piece of cement board to act as a
fire-retardant base. It costs just a few dollars, and it helps
me sleep better at night.
Flanges and strapping. Most
prefab fireplaces are designed to be fastened to the framing
with nails driven through a mounting flange on either side of
the front face. If we've removed the existing trim or fireplace
surround and have access to the front of the unit, we'll fasten
it to the framing with deck screws, which are later concealed
by the trim. In cases where the replacement unit is smaller
than the original, we often have a local sheet-metal shop
fashion additional trim from black 24-gauge sheet steel (Figure
6).
Figure 6.Gaps between a smaller replacement
fireplace and the existing interior finish (top) are closed
with a custom sheet-metal surround screwed to the front of the
fireplace (middle). Existing assembly screws on the fireplace
are backed out enough to allow the notched flange of the
surround to slip into place before being tightened down with a
nut driver (bottom). Where needed, extended trim is added to
the sides of the fireplace as well.
If we removed the existing fireplace from the back, we use a
different method to secure the new unit: After attaching the
sheet-metal surround to the front of the fireplace, we screw
two lengths of plumber's strapping to the framing, wrap them
around the back of the firebox, and join the ends with a
1/4-inch bolt (Figure 7). This acts as a turnbuckle to pull the
unit forward so the metal surround butts against the existing
trim.
Figure 7.
When a new fireplace is inserted from
behind, it's not always possible to fasten the nailing flanges
provided by the manufacturer to the framing. An alternative
method is to fasten metal plumber's strapping to the framing
with deck screws and pass it behind the back of the fireplace
(left). A 1/4-inch bolt slipped through holes in the strapping
acts as a turnbuckle to pull the unit forward so it rests
snugly against the trim (right).
Chases and Roof Penetrations
Today's chimneys typically "snap-lock" together without tools.
Once they are assembled, it's difficult to disassemble them
without damage. A 2-inch clearance is usually required between
the pipe itself and surrounding combustibles, including
insulation. It's especially important to make sure that the
ventilation holes at the bottom of the chimney aren't
obstructed by insulation, because that can reduce the flow of
cooling air between the stainless-steel liner and the outer
wall and create a fire hazard.
Lost and found. It's not
uncommon to find rot and other damage in exterior chases,
usually as a result of leakage at the chase cover (Figure 8).
We also find quite a few beer cans, hardware, and tools left
behind by previous workers and lots of miscellaneous
debris.
Figure 8.The stamped one-piece chase covers
provided by many fireplace manufacturers are a common source of
leaks (left). The author's preferred cover, fabricated by a
local sheet-metal shop, has a soldered collar that extends
several inches above the cover itself (right). A conical storm
collar is caulked to the flue with silicone. The cover is sized
to extend an inch beyond the chase on all sides to prevent
water that drips from the edges from running down the outside
of the chase and rotting the siding.
Repairing or rebuilding a damaged chase is a simple carpentry
project. We will do this ourselves if the customer requests it,
but we prefer not to. Our service area is glutted with low-cost
handymen, and we don't want to compete with them. We also don't
want to be known as a home repair company, preferring instead
to focus on chimneys and masonry.
Through the roof. Whether
the fireplace is mounted in an interior wall or an exterior
chase, a fire-stop spacer and an insulation shield should be
installed at the level of the attic floor. If the chimney
passes through an unused, inaccessible attic space, it can be
left exposed. If it passes through an accessible attic used for
storage, it should be framed in and protected from impact or
contact with people and items around it. The pipe penetration
through the roof is weatherproofed with a flashing kit provided
by the manufacturer or with a rooftop chase (Figure 9).
Figure 9.In applications where the flue exits
through the roof, the penetration can be enclosed in a
site-built or manufactured rooftop chase or left exposed and
weatherproofed with a standard flashing kit, shown
here.
Bob Priesingis the president of Havelock's Chimney
Sweep in Havelock, N.C.
